Squeaky SubFloor - Flooring - DIY Chatroom Home Improvement Forum
Old 07-01-2006, 04:53 PM   #1
Rewards Points: 123
squeaky subFloor
One of my upstairs bedrooms has a squeaky sub floor which has been this way since I purchased the home. I decided to investigate this. I pulled up the carpet and found that the sub floor is particleboard. There are areas where the particleboards meet where the squeaking appears to come from. Is there some sort of glue I can put into the seams to stop this?
jerome8283 is offline   Reply With Quote
Old 07-01-2006, 05:05 PM   #2
How thick is the particle board/subfloor?
redline is offline   Reply With Quote
Old 07-01-2006, 05:08 PM   #3
Rewards Points: 123
I'm pretty sure it is 3/4.
Old 07-01-2006, 09:37 PM   #4
Master Craftsman
Big Dave's Avatar
If the two peices of pb are rubbing together to make the squeak then I would take a saw and set the depth to 3/4 of an inch and saw a kerf right where the two peices rub together. This should eliminate any squeaking and should not affect the structural integrity of the pb.
Dave.
P.S. You could then run a bead of construction adhesive between the boards if you like.
Do one thing at a time, do it well, then move on.
www.bigdaveswoodworks.com
Big Dave is offline   Reply With Quote
Need guidance on subfloor problems in new home. wb1026 Flooring 9 10-06-2009 06:29 AM
subfloor question for hardwood installation metrokarl Flooring 2 05-16-2007 08:37 AM
BAthroom Subfloor Blaze25 Flooring 3 11-17-2006 09:06 AM
subfloor for laminate and tiles mf915 Flooring 10 05-18-2006 04:01 PM
COMPLETE subfloor removal alexschmidt Flooring 4 08-02-2005 11:15 PM
