Squeaky Stairs - Flooring - DIY Chatroom Home Improvement Forum
Old 08-18-2013, 12:45 PM   #1
squeaky stairs
I have old stairs from 1930. They squeak like crazy. I have no access to underneath the stairs. There are nails in the treads. I know nails may cause squeaking. Do I need to remove these nails and apply screws where needed to eliminate the squeaking? Where all do I need to apply the screws? Please help. I'd like to fix the squeaks before installing carpet. Thanks.
zzty00 is offline   Reply With Quote
Old 08-19-2013, 04:14 PM   #2
Rewards Points: 274
First of all check and identify all the nails which are squeaking and then apply screws.
alexjoe is offline   Reply With Quote
Old 08-20-2013, 10:22 AM   #3
hboogz's Avatar
Rewards Points: 97
I'm having the same problem as the OP. I don't have access to underneath and I have about 15 steps most of which are squeaky. The stringer appears in good shape, but the treads and risers could be loose. What options exist without being able to work from underneath ?
hboogz is offline   Reply With Quote
Cures For Squeaky Stairs? g1hrtr Carpentry 7 05-02-2013 10:59 AM
Current house - stairs JulieB Project Showcase 20 04-09-2013 02:38 PM
Questions about building stairs. cvriv.charles Building & Construction 7 12-19-2012 05:04 PM
Building Code Requirements: Basement Stairs (Quantity) dutchswan0311 Building & Construction 27 09-19-2011 07:13 PM
Squeaky stairs in 2 story house HELP!!!! simiesue Flooring 2 06-05-2011 11:06 AM
