Squeaky Hardwood Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 03-12-2012, 06:29 PM   #1
squeaky hardwood floors
Have hardwood installed in living room and bedrooms squeaks in certain spots.The house is a bungelow is there a way that i can fix it from below.Thanks
dodge1972 is offline   Reply With Quote
Old 03-12-2012, 07:00 PM   #2
Pro
JetSwet's Avatar
Rewards Points: 502
When was the hardwood installed?
You can look for gaps between your joist and plywood but really hard to say if it's the hardwood or ply wood. You can put wedges between joist and plywood see if that helps in the caps if u have any.
JetSwet is offline   Reply With Quote
Old 03-12-2012, 07:04 PM   #3
was wondering if i could screw the floor from underneath on a angle through the joist and plywood.thanks.
Old 03-12-2012, 07:10 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
You can also try that but check for gaps 1st this way you know we're to start.
Old 03-12-2012, 07:14 PM   #5
ok thanks alot
Old 03-13-2012, 07:54 AM   #6
Willing to listen
Rewards Points: 223
I had good luck using metal brackets that pull down the subfloor from below made by Squeakender. I used 4 and got rid of 2 major squeaks. You have to be able to isolate the squeak pretty close, and have access...for example one was difficult because it was above my duct work.
Done That is offline   Reply With Quote
Old 03-13-2012, 08:44 AM   #7
Ironlight's Avatar
I've lived in a number of old houses with squeaky floors. As noted, the cause can be either movement of the subfloor relative to joists, or movement of the floor relative to the subfloor. First thing to try is wood shims between the joists and subfloor. If that does not remove the squeak, then 1" screws shot through the subfloor into the floor. It is worth measuring to ensure that you get the screw centered on the hardwood strips as if you hit a seam between boards it does not do much good.
Ironlight is offline   Reply With Quote
Easy maintanence and child friendly Hardwood floors? gante Flooring 11 04-12-2016 11:20 AM
Old Glue on Original Hardwood Floors! gh4444 Flooring 5 02-11-2012 12:13 PM
Options for removing/repairing VERY squeaky hardwood floors? Proulx06 Flooring 0 01-14-2011 09:09 AM
5 Ways to carry on your hardwood floor shining brightly John_smith Flooring 3 02-24-2009 11:56 AM
Hardwood floors: Removal of carpet staples, dried paint, and a discoloration problem proofer Flooring 7 03-01-2008 07:06 AM
