Old 02-19-2011, 10:43 PM   #1
Squeaky floors
I have an older house, beautiful original hardwood floors, problem is they are a bit (a lot) squeaky. I know you can go down in the basement and tap in shims between the floor and the joists, but unfortunately the duct work leaves a good percentage of the floor unworkable. Other than removing all the ducting and fixing, or pounding in nails from above, any solutions?
phantasm72 is offline   Reply With Quote
Old 02-19-2011, 11:38 PM   #2
Super Moderator
Squeaky floors
How old? In the older houses there is usually 1x4 skip sheeting---then 1x2 sleepers--then the hardwood
Often,with that many layers and all those nails--squeaks are just going to happen--not much you can do.
If you decide to try screwing or nailing---remember--there is usually electrical conduit in with the sleepers--(shocking thought,eh?)---Mike---
oh'mike is online now   Reply With Quote
Old 02-20-2011, 09:14 AM   #3
Squeaky floors
The house is about 90 years old
The wiring has been mostly been replaced (it use to be the old knob and tubing type), and is now all visible in the basement. From a quick look, most of the wires seem to be accounted for, running along the joists in the basement, then going straight up into the wall cavities above.
Options for removing/repairing VERY squeaky hardwood floors? Proulx06 Flooring 0 01-14-2011 10:09 AM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 09:50 AM
Fasteners for Squeaky Floors ralphfravel Building & Construction 2 10-18-2009 06:53 PM
Reinforcing Squeaky Wood Floors jelly Flooring 3 11-15-2008 06:38 AM
Squeaky floors forcheck Flooring 5 11-01-2005 09:27 PM
