Old 12-10-2012, 05:58 PM   #1
squeaky floors
We have moved into a house that has very loud floors. Usually I would nail the wood down but there was new flooring installed and we don't want to replace it. How do I stop the squeaking?
Blkngup is offline   Reply With Quote
Old 12-10-2012, 06:14 PM   #2
squeaky floors
With that little info no way to tell.
What is the subflooring made of?
What's the width of the floor joist, free spans, spacing?
You say there's new flooring, what is it.
Not going to like it but all this should have been addressed before the new flooring went in.
Old 12-10-2012, 06:16 PM   #3
An old Tradesmen
squeaky floors
Moved to Flooring forum.
Old 12-10-2012, 06:26 PM   #4
squeaky floors
I thought th
Old 12-10-2012, 06:28 PM   #5
squeaky floors
That's what I thought. Thanks.
Old 12-11-2012, 09:48 AM   #6
squeaky floors
You may be able to address it from below, if you can get to it. And I'll echo Joe's question - what floor covering do you have?
zakany is offline   Reply With Quote
Old 12-11-2012, 09:59 AM   #7
squeaky floors
There is carpet, linoleum, and the cheap wood floor. I've heard it called a floating wood floor. None of it is too hard to replace. Just not wanting to add to the list right now.
Old 12-11-2012, 01:46 PM   #8
squeaky floors
I would try to add some shims from below if you have access from the basement or crawl space.
Awoodfloorguy is offline   Reply With Quote
Old 12-11-2012, 01:58 PM   #9
squeaky floors
Thanks for all the help.
Old 12-11-2012, 02:20 PM   #10
squeaky floors
No problem. Another method is using the squeak b gone. Just google it and you will easily find it. It's scored screws that you can add to the floor that are specially made to break off below the surface.
squeaky floors! analogmusicman Remodeling 4 11-06-2011 02:35 AM
Squeaky floors phantasm72 Flooring 2 02-20-2011 09:14 AM
Options for removing/repairing VERY squeaky hardwood floors? Proulx06 Flooring 0 01-14-2011 10:09 AM
Fasteners for Squeaky Floors ralphfravel Building & Construction 2 10-18-2009 06:53 PM
Reinforcing Squeaky Wood Floors jelly Flooring 3 11-15-2008 06:38 AM
