Old 10-31-2005, 09:06 PM   #1
Thumbs up
Squeaky floors
I am in the process of having my house recarpeted. My home is 12 years old and my sons floor squeaks terrible. I painted all the rooms with various coats of paint and am now waiting to have the carpet installed Monday the 7th of November. I decided to try fixing the squeaks. I used a utility knife and cut the old carpet back. I used 2 and 1/2" drywall screws and sank a lot of them in the joists. that did not stop the squeaks. I stand on both the joists and rock back and forth and the squeaks are real loud and annoying. What should be my next move? What can I do? Thanks
forcheck is offline   Reply With Quote
Old 10-31-2005, 09:17 PM   #2
jproffer's Avatar
Squeaky floors
Squeeks are usually nails rubbing the wood. If you're never going to want to refinish the wood...ahem...IF YOU'RE *NEVER, EVER* GOING TO WANT TO REFINISH THE WOOD ...try digging the nails out and replacing them with screws, or place the screws right next to (almost on top of) the nails, but it's better to just remove them if you can.
Notice the "usually" in the first sentence. If this doesn't stop it, come back and someone may have other ideas. This is happening monday the 7th right? So we have time.
jproffer is offline   Reply With Quote
Old 10-31-2005, 10:24 PM   #3
Contractor
Squeaky floors
If it is a limited area, see if you can find 'GitRot'. It's a penetrating epoxy. You will have to drill small holes through the flooring and into the joists, I'd suggest 1/8" (it will tell you 3/16 in the instructions).
As far as ever going back to the original wood, you can always drill and plug the holes. Just gives an old floor more character.
Teetorbilt is offline   Reply With Quote
Old 11-01-2005, 12:06 AM   #4
Squeaky floors
If yor are dealing with a subfloor, (plywood, osb, etc), you should be able to get the squeaks. If it is subfloor put more screws in and make sure you hit the joists. Look for movement like a plywood joint, (seam) or a nailhead. More screws. If you still can't get it it might be in the ductwork or a joist hanger or a nail from the joist into a lower wall. I go after them no matter what but you might not want to go that far. Make sure those screws a sucking up tight. I like a screw that is not threaded all the way. They draw things together better. HS
K2eoj is offline   Reply With Quote
Old 11-01-2005, 09:11 PM   #5
Squeaky floors
I came home today and started putting in 5/16" x 3" lag bolts and the squeaks were still there. I then got my saw and was getting ready to cut the flooring out when I decided to check this site out. I read about the nails and the wood rubbing together and I thought,DUHHH, why didn't I think of that. I got my cats paw and started pulling nails from the noisy area and WAHLAA that was it. i pulled as many nails as I could and started sinking 3'16 x 3" decking screws about every 4 inches or so. What I found as I pulled the nails that out of maybe 50 nails pulled only about ten were ringed and coated the others were commons. I remember when I had this house built I requested that all floors were to be screwed and glued. I was assured by the realator that My floors would never speak. Yeah right. Well anyways thanks for all the great advice.
Old 11-01-2005, 09:27 PM   #6
Contractor
Squeaky floors
forecheck, Your're kidding us right? How many beers?
More On This Topic
Learn how to remove side trim board to remove the siding on you house from a professional contractor in this free DIY home improvement video. Read More »
DIY wedding decorations can be as simple as a basket of fruit or as complicated as an ornate floral bouquet. Experiment using a variety of materials and edible accents to create custom wedding decorations with information from an experienced event... Read More »
DIY Halloween Decorations
DIY Halloween Decorations by expertvillage
Want to save money on Halloween decorations? Learn do it yourself ideas for indoor Halloween decorations in this do it yourself Halloween decorations video. Read More »
DIY Soundproofing
DIY Soundproofing by Arthur Noxon
In DIY soundproofing, sheet rock needs to cover any windows. Soundproof a room personally with tips from an acoustics specialist in this free video on soundproofing. Read More »
Refinshing floors before painting walls? ponchoman1 Flooring 6 03-14-2009 05:21 PM
Washing my wood floors J187 Flooring 1 11-14-2006 11:13 PM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 05:23 PM
Dogs and Floors Flyergirl Flooring 9 03-18-2005 01:29 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
