Squeaking Hardieboard Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 06-03-2010, 01:55 PM   #1
squeaking hardieboard floor
Hi everyone,
I'm in the midst of my bathroom renovation. i put down an entirely new 3/4" plywood subfloor (attached with adhesive and screws). about 2 months later i got around to putting down 1/4"hardieboard with mortar and screws. yesterday, about 6 weeks later my floor has started to squeak along the tub. I still have not put the tile floor down. I'm not sure if it's the hardieboard/subfloor that is squeaking or the subfloor/joist that is squeaking. Before i put the tile on the floor i figured i would check for advice.
Not sure if i should just leave it and let it squeak or try to fix it. if i fix it...how??
thanks!
Jamie
jbitt is offline   Reply With Quote
Old 06-03-2010, 02:33 PM   #2
Knows everything but that
Rewards Points: 150
Be sure its not the tub against the new wood or just the tub against the wood under it. Its a good bit hotter in NJ than it was 6 weeks ago and tubs and wood expand a lot!
JakAHearts is offline   Reply With Quote
Old 06-03-2010, 08:25 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The Hardi has nothing to do with it. More than likely the ply has expanded and is rubbing together or rubbing on something.
XXX
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Refinishing Painted Wood Floors MicahPDX Flooring 4 11-28-2008 10:23 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
Help wih floor extremer1519 Flooring 1 12-27-2005 06:33 PM
