Sprucing Up Wood Floor Without Sand/re-finish - Flooring - DIY Chatroom Home Improvement Forum
Old 06-30-2011, 05:52 PM   #1
Rewards Points: 256
Sprucing up wood floor without sand/re-finish
I am getting ready to sell a house.
It has approx 1000 sq ft of wood floor.
It appears to be a conifer species, refinished once with fairly major sanding, as evident near the irregular rock fireplace which shows thicker and darker.
Its in pretty good shape, but is dull in traffic areas.
What are the best options for a quick/cheap refinished look?
I imagine the poly won't stick if I just put a coat on as-is. Should I buff, clean, chemical de-gloss?
I really don't want to sand.
Planning on doing a couple test sections tomorrow, then applying whatever worked best all over.
michaelcherr is offline   Reply With Quote
Old 06-30-2011, 06:02 PM   #2
the Musigician
DangerMouse's Avatar
I don't see why not. We just cleaned our old wood floors and re-poly'd them!
It worked quite well.
DM
Old 06-30-2011, 07:36 PM   #3
woodman58's Avatar
You should always screen a floor before recoating it. If you do not you will end up with bubbles in the finish down the road. Use a 120 grit screen and keep the buffer or osillating sander moving. You just want to scratch the finish a little so the new coat will have a surface to addhere to.
woodman58 is offline   Reply With Quote
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
Clear exterior wood finish for natural color orrd Painting 2 07-06-2008 03:38 PM
Giving wood floors a new finish MystiLatte Flooring 1 04-20-2008 05:53 PM
Stair Finish - wood or paint TRM Painting 3 01-16-2008 12:33 PM
Wood Finish to Stair Rails propilot5000 Painting 1 01-09-2007 06:22 PM
