Spacing Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 12-03-2005, 04:08 PM   #1
Spacing flooring
I'm helping my in-laws with unglued tongue in groove laminate flooring. there is a minimun 3/8 to 5/8 inch space required. The sheetrock doesn't reach the floorand the gap is large enough for the flooring to fit under. Will it cause a problem to have a larger space by going in front of the sheetrock. We don't want the flooring to shift.
Also it says to seal the cement and then put down a vapor barrier, is the sealant a must?
Thanx
Servant_ is offline   Reply With Quote
Old 12-03-2005, 07:31 PM   #2
jproffer's Avatar
Rewards Points: 706
The recommended gap is between the flooring and the nearest obstacle, in your case, the framing behind the drywall. To answer your question, it wouldn't necessarily HURT anything to leave the gap from the edge of the drywall as long as it will be covered with base, but I don't think it's necessary.
As far as the sealant: It's not a must....unless of course you want to keep the manufacturers warranty in force. They will look for (and find) ANY reason not to pay off on a claim, and any deviation from their instructions qualifies as that reason.
jproffer is offline   Reply With Quote
Wood flooring in basement DIY4EVER Flooring 9 07-20-2007 02:04 PM
Chlorine Resistant Flooring for Bathroom herbolaryo Flooring 7 05-22-2007 10:05 PM
Hallway Flooring jay1000 Flooring 3 05-30-2006 07:04 PM
Gameroom basement flooring? PaulMcC Remodeling 4 03-09-2006 10:08 AM
IAQ and flooring. Briefly. Benhamcarpetguy Flooring 12 03-24-2005 09:53 PM
