Spacers For Laminate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 07-27-2013, 10:52 PM   #1
Question
Spacers for laminate flooring
I am installing laminate flooring in our family room. I did not take off the baseboards, as there was carpet, therefore there is plenty of room for the flooring to "float" under the baseboard. I will put quarter round down once the laminate is installed. The problem that I am having is that the spacers keep sliding under the baseboard and will not stay in an upright position. Any recommendations?
SuZQu is offline   Reply With Quote
Old 07-27-2013, 11:45 PM   #2
I had the same problem where my drywall is gapped off the slab. I made my own spacers.
Even Further is offline   Reply With Quote
Old 07-28-2013, 12:04 AM   #3
I use the off cuts from my rips. Tack 'em to the baseboard? I always remove the baseboards and tack to the wall where the base will be going though.
MissKat is offline   Reply With Quote
Old 07-29-2013, 09:03 PM   #4
That's a good idea....thanks
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 4 06-07-2017 06:24 PM
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-18-2012 11:51 PM
Lumber Liquidators Bud Cline Flooring 11 10-28-2011 02:00 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 08:00 PM
