Soundproofing Floors - Flooring - DIY Chatroom Home Improvement Forum
Old 07-20-2011, 03:03 PM   #1
Looking for some advice on this.
I own an older triplex in Toronto. I live on the top floor and am redoing the floors to improve both the look and reduce noise from my tenant.
I have already ripped up the subfloor and put two layers of Roxul Safe n Sound between the joists. I have installed 5/8" plywood over the joists now. This helped some but I want more improvement.
I would prefer to install hardwood as the finished floor. But I would be fine with engineered wood as well.
I have spoken to a local soundproofing retailer and the suggestion was to have 2 layers of underlay (one for impact noise and the other MLV). He also suggested I use an engineered wood as putting nails through the underlayment will reduce or eliminate the improvement gained. He suggested gluing the engineered wood down to give a more solid feel.
Any suggestions on the best way to reduce the sound coming through the floor would be appreciated.
Thanks in advance.
ashcakes33 is offline   Reply With Quote
Old 07-20-2011, 03:35 PM   #2
Rewards Points: 85
How much did Roxul Safe n Sound between the joists help the noise?
quincy is offline   Reply With Quote
Old 07-20-2011, 03:40 PM   #3
It helped.
For reference when I started the project the floor consisted of.
Berber carpet over an underpad. Then there was a layer of old strip hardwood and then the 5/8" planks that were the old subfloor. I removed all of that.
With the Roxul and the plywood I would say there is already a slight improvement in sound.
The Following User Says Thank You to ashcakes33 For This Useful Post:
quincy (07-20-2011)
Old 07-21-2011, 08:46 AM   #4
Am planning on doing something similar in a condo I own. Would love to know the results once you finish.
DesignEye is offline   Reply With Quote
Soundproofing floors. ANGRYKOREAN General DIY Discussions 5 07-12-2011 03:40 PM
Resurfacing Wood floors roxksears Building & Construction 2 10-23-2009 08:50 AM
Want to try to refinish hardwood floors and parquet floors proofer Flooring 11 04-20-2008 05:59 PM
Atlantic et al: Soundproofing Ceiling between 1st and 2nd floors BigJimmy Building & Construction 3 10-25-2007 05:35 AM
Washing my wood floors J187 Flooring 1 11-14-2006 10:13 PM
