Old 09-11-2008, 02:08 PM   #1
Solid Hardwood direction
How important is it to install the hardwood perpendicular to the floor joists?
We are adding prefinished 3/4" solid oak flooring to a hallway. The floor joists are parrallel to the hallway so to install the flooring perpendicular to the joists would involve a lot of cutting, plus it looks better the other direction (the long way)
Thanks for the advice
daxinarian is offline   Reply With Quote
Old 09-12-2008, 03:56 PM   #2
As I seem to recall (and it's been years since I worked for a flooring installer so take this for what it's worth) you will either need to add blocking from underneath or another layer of 3/4 subfloor.
You are correct that it will only look good run the long way.
When all else fails, call or email the manufacturer.
Good luck,
Sam
samjack is offline   Reply With Quote
Old 09-15-2008, 02:02 PM   #3
J Calvin Construction
jcalvin's Avatar
Run it perpendicular to the floor joists!!!
Do not pass go!!!
Do not collect $200!!!
I mistakingly allowed a Homeowner talk me into installing it parallel for the "look" issue. I made him sign a waiver and went on about the install. By the time the job was over, everyone involved regreted it.
Cal
You hired WHO?
jcalvin is offline   Reply With Quote
Old 09-15-2008, 03:31 PM   #4
Did you add blocking perpendicular to the joists? Same difference if you do that.
Old 09-17-2008, 05:42 PM   #5
jcalvin's Avatar
No I didn't do that. I gave that as an option but they didn't want to pay the money. You live and learn.
Cal
You hired WHO?
Old 09-17-2008, 10:36 PM   #6
How much blocking do you need to add?
Old 09-18-2008, 03:13 PM   #7
jcalvin's Avatar
I would put it on a maximum of 24" oc. I would prefer it to be on 16". That will be a lot of blocking if you are wanting to turn the floor in your entire house. I hope you have a full basement.
Cal
You hired WHO?
Hardwood Floor - Reversing Direction PhilC Flooring 14 04-07-2010 04:23 PM
Hardwood - engineered vs solid? cbeingessner Flooring 12 05-19-2008 11:37 AM
Direction of Hardwood floors kprice General Discussion 2 03-12-2008 09:36 PM
Does 5" Hardwood Solid need to be glued down as well as nailed down. reibuild Flooring 2 08-03-2007 11:37 PM
3/4" hardwood, same direction as joists? zel Flooring 13 05-15-2007 09:50 PM
