Which Is Softer...cork Glue Down Or Cork Laminate? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 10:34 AM   #1
Which is softer...cork glue down or cork laminate?
I am putting in a cork floor in my kitchen as was wondering if there was a difference between the 2.
Is one better than the other ....is one softer than the other?
What about thickness of the glue down? Is thicker better or will that cause problems? I have 2 rolling butcher blocks/islands that are 2' x 3'. Will this be too heavy for a cork floor?
Also, is pieces become damaged, is it easy to replace ther cork glue down or laminate?
howdihi is offline   Reply With Quote
Old 08-20-2011, 02:33 PM   #2
woodman58's Avatar
There is a difference in the 2. Cork tiles are only 1/8in. thick. Cork laminate is thicker and has cork on the bottom. You can use cork underlayment under the tiles (or the laminate) to make it softer. You have to make sure it is very dense and full spreed with a urethane glue. Glue only under the tile, loose lay under laminate. Cork is easily repaired. On tile you will just replace a tile. On the laminate it is a little more tricky. Depending on the pattern you take an extra peice and find a peice of the pattern that is big enough to cover the damaged area. Take an exacto knife and cut the peice of the pattern on the pattern. Slowly pry and scrape the pattern off. Take care not to damage it. Hold the peice over the damaged area tightly. Use the exacto knife and trace the peice. Pull the damaged peice out and glue the new peice in with a premium wood glue. If done properly the repair will be invisible.
woodman58 is offline   Reply With Quote
Old 08-20-2011, 02:54 PM   #3
Thanks. Which one is softer or more comfortable to stand or walk on? Are they the same? Or is the laminate better?
Old 08-20-2011, 04:46 PM   #4
woodman58's Avatar
They both have a 1/8" wear layer. They will feel about the same. The laminate will be easier to install. I forgot to mention that in a wet area (kitchen, bath) I always put two coats of polyurithane over the floor to make sure no water gets in the cracks. It is not nessisary with tile as long as you use a thin spread tile addhisive. Cork is impervious to water. You still should use the poly on the laminate. The cork may not absorb water but, the core will.
Cork under laminate Rustigger Flooring 3 09-20-2010 01:48 PM
Laminate to cork? tracyanne Flooring 3 02-24-2010 10:01 AM
What type of adhesive should I use to glue down accoustical cork to a concrete floo Fixitgeorge Flooring 2 03-20-2009 07:54 AM
Counter top plastic laminate Gerry Kiernan Interior Decorating 4 10-13-2008 10:44 AM
Laminate flooring over old glue?? TomC723 Flooring 2 08-19-2008 12:33 AM
