Soft Spot In Laminent Floor? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-30-2006, 01:08 PM   #1
soft spot in laminent floor?
hello im going to put ceramic tile down in my kitchen. After i pull the laminent up how do i fix this soft spot. Will some type of mortar under the cement board be enough assuming its not due to water damage. Do i need to pull the whole peice of plywood up? if i do what do i do about the cabnit in front of it?
ragempt is offline   Reply With Quote
Old 08-30-2006, 05:52 PM   #2
Do you have access to the floor from below?
redline is offline   Reply With Quote
Old 08-31-2006, 09:35 PM   #3
Floorwizard's Avatar
soft spot no good.
Mortar will not fix.
pull up lywood and look. or go from under and look if you can
Floorwizard is offline   Reply With Quote
Old 09-01-2006, 09:15 AM   #4
thanks guys. I can get into the basement and look up. what do you want me to do then< besides the obvious asses the situation? so motar wont stabilize? why not
Old 09-03-2006, 08:06 PM   #5
pull up the floor and look at what you see. let us know
Leaking bathroom floor patatura Flooring 6 12-06-2008 07:30 PM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 08:57 PM
sagging floor - attach LVL? tmenting Building & Construction 3 01-30-2007 02:07 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Help wih floor extremer1519 Flooring 1 12-27-2005 07:33 PM
