SoFla Laminate- Terrazo Sealer Needed? - Flooring - DIY Chatroom Home Improvement Forum
Old 09-30-2007, 04:17 PM   #1
SoFla Laminate- terrazo sealer needed?
Hello- I'm a newbie
South FLorida home with about 1200sqf to lay laminate wood flooring over an original terrazo floor. What prep work need to be dome to the terrazo? ANd if a sealer is needed do I still use the recc. 6mil.? or whatever mil. of poly sheet material?
out
Dutchman is offline   Reply With Quote
Old 10-02-2007, 09:16 PM   #2
Originally Posted by Dutchman View Post
Hello- I'm a newbie
out
If you are using foam I prefer the 2in1 foam. It provides the moisture barrier and cusion. If it is flat within tolerence you should'nt need any prep. You will need moisture barrier.
flooring dude is offline   Reply With Quote
Old 10-02-2007, 11:03 PM   #3
Floorwizard's Avatar
I concur.
Floorwizard is offline   Reply With Quote
How do you install a toilet over Laminate? yohan Flooring 6 07-22-2008 08:07 AM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
Size of laminate layout before t-joints are needed wingman Flooring 1 06-22-2006 10:42 PM
