Soaked Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 03-18-2014, 06:05 PM   #1
Soaked floor
Hello everyone, new guy here, so don't beat me up too bad. I don't have much experience with home repairs so I'm here for some help. The water heater in my parents house started with a small undetectable leak, the leak wasn't noticed noticed until the vinyl tiles in the laundry room began seeping water out of the seams. The water heater has been replaced but the floor is still soaked, there are 3 layers of vinyl tiles stuck down on the slab. Is this something that can dried out or should we go ahead and rip up all the tiles down to the slab and start fresh? If I do end up ripping up the tiles I will probably need some advice on that too, never done any flooring but I guess this is a good time to learn. Thanks!
jbsprogect is offline   Reply With Quote
Old 03-18-2014, 06:10 PM   #2
Rewards Points: 14,294
Are these glued down tiles, or peel and stick tiles.
Start by sucking up all you can ASAP with a shop vac.
Run a dehumidifier for about a week.
See if the tiles are loose.
Do not put this off or your going to be dealing with mold.
Old 03-18-2014, 06:22 PM   #3
The bottom tiles are glued down and the top two layers are stick on. I will be picking up a dehumidifier later today.
Old 03-18-2014, 07:38 PM   #4
DIY staff
Rewards Points: 7,174
Lift out the loose ones and shop vac the open area---let us know the color of the old glue----that is one of those jobs that can be really easy or a huge pain in the back---You never know until you start--
Old 03-19-2014, 09:39 AM   #5
Alright, I pulled up the tiles behind the water heater; confirmed two layers of stick on tiles then the bottom tiles are glued down with black glue. I think this leak has been going on awhile too, the smell when I pulled up the tiles smells like rotting wood and swamp.
Old 03-19-2014, 06:08 PM   #6
DIY staff
The old glue is called 'cutback' --so that is an old installation---
Good news--the tiles should pop off easily ---
Bad news--the cutback and original tiles might contain some asbestos
I suggest you get a bent scraper and start pealing up the old tiles--sprits the stuff with water to keep dust down---
repair any rotten wood---then get back to us for ideas on adding a new floor covering for your folks---
Old 03-19-2014, 06:40 PM   #7
Tileguy
JazMan's Avatar
Rewards Points: 422
Hopefully there isn't any wood products involved since this is a slab floor.
I recommend removing all the tiles as already stated. Let us know the condition of the slab once you see it, post a pic if you can. Don't freak out too much about the asbestos. It's not gonna hurt you. Just don't grind it. mist as Mike said.
Jaz
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 09:12 AM
Termite wood floor as sub-floor gtimk4 Flooring 1 09-21-2011 06:30 PM
Dryer duct hole thru band joist & floor joist justplumducky General DIY Discussions 12 10-05-2010 12:31 PM
2nd floor air flow/pressure fgillis HVAC 7 02-24-2009 04:58 AM
Levelling wood floor gomi_otaku Building & Construction 13 11-27-2008 07:45 AM
