Smoothing Out Basement Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 11-04-2011, 02:08 PM   #1
Unhappy
Hi I am new to this blog and am hoping someone may be able to guide me through my basement troubles.
My basement was badly flooded during Hurrican Irene resulting in the need to completely gutt and sanitize.
Unfortunately, it was an occupied space and needs to be refinished again. I have installed a french drain and upgraded my sump pump but i noticed many areas in my floor that have pooling issues when water is present.
The floor is not smooth by any stretch. I'm wondering if there is a "quick fix" for this? What i mean by this is, i would like to avoid tearing out all the existing concrete and repouring if there is an easier, efficient way to fill in these dents and crevices in the floor. End result, I had planned to epoxy the floor. Any input would be greatly appreciated.
pnk1113 is offline   Reply With Quote
Old 11-04-2011, 02:12 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes there is but it won't be in-expensive.
Old 11-04-2011, 03:56 PM   #3
Smoothing out basement floor
Ok. I have a contractor who gutted the basement and cleaned it up, who offered no solutions and planned to just paint the floor. Gave me a quote of $35,000 to replace my boiler, sump pump, water heater, put up new walls, do the floors & paint. So roughly what is "won't be in-expensive". I beleive I'm being ripped off so if there is a way i can maybe get him to fix the floor - I'll do the rest if i have to in order to save money.
Old 11-04-2011, 05:13 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
None of us that participate here are here to give estimates. This is a DIY Website.
If you have a contractor to deal with the floor then that is who you should be getting estimates from.
The thing to do in that case is to solicit additional estimates from other local contractors.
Old 11-04-2011, 11:14 PM   #5
There are some self leveling products that may be used to make the floor smooth. TEC products makes a good one. Dramatic products is another good one also. Be sure to use primer before pouring self leveler.
plowboy is offline   Reply With Quote
Old 11-06-2011, 11:22 PM   #6
Clean the concrete surface and remove all stains from the surface. Determine how level the surface is, and what kind of shape it is in. A string level works well along with the tape measure to determine the amount of variance, and location of the variance, on the surface. Go out and buy a smoothing product called latex screed you can get it from your builder`s supplies. Mix as per instructions and apply 3mm on your floor with a flat trowel.
Kaylee is offline   Reply With Quote
Old 11-07-2011, 06:37 AM   #7
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 12
It's a bad idea to use any latex based filler on a floor. Cementious based should always be used.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 11-07-2011, 07:20 AM   #8
DIY staff
Rewards Points: 7,174
Self leveling compound is the product---There is a learning curve applying it. It doesn't 'self vevel' very well and needs some help.
If you are interested come back and one of us will give you the low down.---Mike---
oh'mike is online now   Reply With Quote
laminate flooring over basement door in floor... tonyg1 Flooring 0 08-18-2011 03:35 PM
Leveling a Basement Cement floor Tinkertom67 Flooring 0 08-14-2011 01:49 PM
Vapor barrier & insulation for basement floor dvsanfor Flooring 5 09-26-2010 11:01 PM
Finishing a cement basement floor with carpet and tile - no subfloor? vseven Flooring 2 09-21-2010 10:41 AM
Basement floor reno D.RED Flooring 1 06-21-2006 03:20 PM
