Smooth Transition - Flooring - DIY Chatroom Home Improvement Forum
Old 02-01-2008, 08:24 AM   #1
Smooth Transition
"I have two questions
1. I have a new addition and the subfloor of the addition is 1/4" lower than the exiting house and with like to install laminate floor continue from the exiting house thru the addition. What should I used to even the subfloor?
2. I have two bathroom in this addition, I'm planning to install ceramic tile on and the require to thick the subfloor which will make this floor 5/8" higher than the laminate floor. What can I used to make a smooth transition?"
crouchra is offline   Reply With Quote
Old 02-01-2008, 09:42 AM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Add 1/4" layer of plywood.
You can't have it both ways. Adding 1/4" to the laminate area will help some but variations in transitions are normal unless the structure was originally built to address the anticipated variations.
Wood to Tile transition? sandyman720 Flooring 3 10-15-2007 12:30 PM
Need some transition moulding advice... confused Flooring 4 08-24-2006 04:35 PM
how smooth is smooth?? cletus Flooring 2 06-16-2005 04:06 PM
