Smell From Used Engineered Wood Causing Diziness - Flooring - DIY Chatroom Home Improvement Forum
Old 04-10-2012, 12:57 PM   #1
Rewards Points: 12
Smell from used engineered wood causing diziness
I bought some second hand engineered wood which is about 3 years old and was apparently previosuly installed in an office block.
Since buying them I noticed a sharpish smell coming from them. It is definately from the wood I'm not sure if it is from the back of the wood planks or the click parts which look like they are made form cardboard.
Anyway this smell was causing me and my friends diziness. Does anybody know what this smell is?
When I lay it down will these fumes completely go? I tried a few pieces and noticed some planks had small gaps between them although I could probably fill these up with wood filler. In any case I am concerned the smell is a toxin which will come up throgh any gaps and pollute my air.
Chlorinated is offline   Reply With Quote
Outgassing Causing Awful Smell in Very Old Flooring, What Should We Do? NeedUrHelpNOW Flooring 13 05-07-2011 11:30 PM
engineered wood flooring adhesives moejoe Flooring 1 07-21-2010 10:26 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 01:51 PM
Engineered wood failed under refridgerator BlueBSH Flooring 15 11-20-2009 11:13 AM
Engineered wood glue requirement - Very expensive cprao Flooring 15 11-03-2009 10:52 PM
