Smell In Finished Basement Of Newly Purchased Home - Flooring - DIY Chatroom Home Improvement Forum
Old 07-14-2010, 10:45 PM   #1
Hi....I'm new home ownership and have a question about my finished basement. It rained hard last night ...the first rain since I moved in. there is now a very strong urine odor in the basement. it has a carpet glued to the floor but when I get down close to it and smell it...I don't smell the odor in the rug. Could it be somewhere other than the carpet. Or is my nose just playing tricks?
My new home started to smell after a heavy rain. It has a strong smell of urine in the finished basement area only. It does have a carpet but I am not sure the smell is coming from the carpet??
2 threads on same topic merged
triathloncathy is offline   Reply With Quote
Old 07-15-2010, 10:24 AM   #2
Rewards Points: 5,336
Sounds like the previous owner had pets. Have the carpet cleaned and get a dehumidifier.
Ron
The Following User Says Thank You to Ron6519 For This Useful Post:
triathloncathy (07-16-2010)
Old 07-15-2010, 11:21 AM   #3
Do work
Rewards Points: 81
I run a de humidifier in my basement during the spring, summer and fall. You might want to try that.
liquidvw is offline   Reply With Quote
The Following User Says Thank You to liquidvw For This Useful Post:
Old 07-15-2010, 11:24 AM   #4
Does it come from the floor drains?
DownRiverGuy is offline   Reply With Quote
Old 07-15-2010, 11:34 AM   #5
Thanks Ron....I won't panic...
Old 07-15-2010, 03:32 PM   #6
make sure your carpet cleaner uses a good urine removing treatment like molecular modifier, let it set a couple hours, extract and spray with mircoban. that 3 step process is used frequently in many of our urine jobs {i own a carpet cleaning and flood damage business}
racebum is offline   Reply With Quote
The Following User Says Thank You to racebum For This Useful Post:
Old 07-15-2010, 04:52 PM   #7
Household Handyman
Rewards Points: 1,408
It would be a long shot in today's world: But IF you're carpet has ANY hemp backing at all, this stuff will smell like old urine when wet. The only way I remember to check is to pull up the carpet at one corner and examine the carpet backing closely. Most of the newer stuff is synthetic, but some of the better companies still will use a synthetic/hemp blend. David
The Following User Says Thank You to Thurman For This Useful Post:
Old 07-15-2010, 05:46 PM   #8
If you can, tear out a small piece of carpet in an area where it won't be noticed, soak it, place it in tupperware, put it outside in the hot sun. Then wait for a while and open it.
If it smells the same as the basement smell, the problem is your carpet is getting wet.
If it doesn't, it is either a urine stain somewhere on the carpet or something else entirely. For me I'd want to find out.
Troglodyte is offline   Reply With Quote
The Following User Says Thank You to Troglodyte For This Useful Post:
Old 07-15-2010, 08:49 PM   #9
It would simplify the answers if this was only posted in one forum.
Ron
Old 07-16-2010, 08:59 PM   #10
great help
Thanks so much for your generous responses. I have purchased a dehumidifier and an air purifier. They have been working hard all day and the smell is MUCH better. I have no floor drains and I used a black light to look for stains but non appeared. Not sure if that method really works. There is also a hung ceiling. and dry wall in this area. Cathy
Old 07-17-2010, 06:57 AM   #11
DIY staff
Rewards Points: 7,174
Some fiberglass insulation will give off an odor when wet. Next time it rains remove a few ceiling panels and sniff around.
This is probably not the problem--however,you said that there was no floor drain---I bet there is,buried under the carpet---on very rare occasions the P-trap will go dry and let a bit of sewer gas into the room--not a urine smell--
-----Mike------Welcome to DIY,Cathy
triathloncathy (07-17-2010)
Old 07-17-2010, 10:04 PM   #12
Wow! this is very good news! I'll keep an eye on those possibilities. Thanks so much!
smoke alarm was sealed off in finished basement Stl_home General DIY Discussions 4 06-22-2010 08:47 PM
Sewer smell in basement BangHeadHereX Plumbing 2 09-15-2009 02:22 AM
Sewer gas smell in basement from sump pump mirage212 Plumbing 15 10-23-2008 07:09 PM
New home purchase... basement moisture kevsays Building & Construction 1 05-04-2008 08:35 PM
Basement Flooring for Home Gym DIYamateur Flooring 10 02-05-2007 09:59 PM
