Small Quarter Round Moulding - Flooring - DIY Chatroom Home Improvement Forum
Closed Thread
Old 09-05-2006, 02:57 PM   #1
Rewards Points: 12
small quarter round moulding
Hi,
I'm in the middle of glueing laminate flooring on staircase. I'd like to put quarter round moulding at the corner (where riser and tread meets), to cover the "bad" cuts. The typical quarter round moudlings I see are like 3/4" thick. Are there any quarter round moulding that are smaller (like 1/4" ) ?? If so, where can I find them ?
Also, I see sealants (for gap filling) sold in Home Depot (under Pergo or other brand). Has anyone tried them ? Does it look okay after application ?
mf915 is offline
Old 09-05-2006, 09:28 PM   #2
Floorwizard's Avatar
if the filler is applied nicely it can look real good.
Quarter round is pretty standard on depth.. you could attempt to rip it down on a table saw if you own one although it can be a tricky speedy spear if you do not look out.
Floorwizard is offline
Old 09-08-2006, 06:14 PM   #3
Rewards Points: 77
If done properly there should be no need for 1/4 round.
Cut edges should be covered by factory edges, if laid out right that would be the groove edge covering the cut edge.
I've installed hundreds of stairs and never needed 1/4 round to cover rough cuts.
Do you have a table saw? If not, clamping a straight edge to piece to be cut and using the proper blade will give a clean cut. Any small and I mean small chips can be smoothed with a mill file.
Zero Punch is offline
Old 09-13-2006, 12:24 AM   #4
Good point Punch.
I also used to use masking tape where I am going to cut to prevent chips.
Old 09-13-2006, 01:13 AM   #5
I blame ProWallGuy
Rewards Points: 150
Check with your local hardware store and ask for screen moulding. Its much smaller.
Double A is offline
Old 09-15-2006, 10:01 AM   #6
Rewards Points: 12
thanks for the replies...
I don't have a table saw... i have circular saw and jig saw.
I'm actually done with the stairs - but if i decide to do the stairs in the basement, i will definitely try out the "masking tape" tip. I use jig saw (18 teeth) and on many occasions I get chips.
I have to say - stairs is the most difficult part of the house (for a DIYer like me). For almost all other parts of the house, I used molding to cover the edges. So no need for perfect cuts. As the pros mention, the size of every step is different - and it's true !! A lot of times it's not even true rectangle. So i do see some small gaps on the sides. I probably will leave them the way it is.
For the gap between riser and tread, i used the nail hole filler (the one for stairnose available at HD)... and i guess it came out alright.
mf915 is offline
Old 09-16-2006, 11:55 PM   #7
Middle aged floor guy
Donedat's Avatar
You can pick up a table saw for as little a 100 bucks from HD or Lowes...for the next time around.
Donedat is offline
Old 09-29-2009, 12:52 PM   #8
laminate on stairs
Just a reminder I did my stairs,laminate is made with a wax emulsion so it is terrible on your blades.I would buy a decent table saw and a blade .I paid $100.00 for my blade.also measure all points on the stairs.I find that builders make them quickly.So you might have to adjust your blade.also i used pl100 calking glue to hold them down.
Just a thought
iceman40 is offline
Old 09-29-2009, 01:01 PM   #9
Too Short? Cut it Again!
1/4" QR and big shoes under force are not going to be a good combination. I think you will find that stuff will break on you in no time.
user1007 is offline
Old 09-29-2009, 02:45 PM   #10
stairs
Dont allow shoes in the house
solve the problem
iceman40 is offline
Old 09-29-2009, 09:39 PM   #11
This thread is 3 years old
I'm thinking the floor is done
Scuba_Dave is offline
Old 09-30-2009, 01:14 AM   #12
good call
Closed Thread
moulding, laminate flooring sequence, need quarter round? KUIPORNG Flooring 6 03-10-2009 01:45 AM
Quarter round in basement? xray328 Carpentry 5 07-24-2007 07:08 AM
Installing Quarter Round shanmon Flooring 4 07-19-2007 01:59 PM
Quarter round on round outside corners biyoba Flooring 4 01-07-2007 08:39 PM
Laminate Flooring Quarter Round Cuts no3jack Flooring 1 12-11-2006 09:30 PM
