Small Mosaic Floor Tile - Flooring - DIY Chatroom Home Improvement Forum
Old 03-11-2014, 12:07 AM   #1
Rewards Points: 39
small mosaic floor tile
HI I recently tile my floor with 12x12 tiles made of octagon and diamond shapes. I let it set for 24 hours before I walked on it. I've noticed that the smaller diamond shaped pieces pop and crack and are loose under foot?
I haven't grouted yet but am wondering what to do. I was generous with my thinset coverage but it seems that some of the smaller pieces may not have a strong bond. I am including a pic. Thanks
tiki16 is offline   Reply With Quote
Old 03-11-2014, 06:34 PM   #2
Tileguy
JazMan's Avatar
Rewards Points: 214
Well yeah, if they're loose there is not a strong bond, you're right. If you used the right trowel and procedure what went wrong could be that you didn't beat the tiles down with a grout float.
Closely inspect and remove all the loose pieces and set them individually.
Jaz
JazMan is online now   Reply With Quote
Old 03-11-2014, 07:32 PM   #3
Rewards Points: 39
I don't know I used a section of 2x6 to press down on them. The thinset is a brand new bag. What if I used a really strong fortified grout, would that help to hold them in place?
thanks
Old 03-11-2014, 07:54 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 214
What do you mean by "really strong fortified grout"? Grout fills the gaps.
A 2x6 is not the right tool to use, it's not cushioned, it won't bend with the floor.
Jaz
Old 03-11-2014, 08:09 PM   #5
Rewards Points: 39
I thought maybe the grout would help hold it in place. If not guess I have to rip it out or take my chance. That's a bummer cus I've done tile jobs before and never had this problem.
Old 03-11-2014, 09:09 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 214
Another reason we charge more for mosaics.
Take a utility knife to cut the netting lift the tiles. Apply a small dot of thin set and set.
Just for info, which thin set did you use and over what?
Jaz
Old 03-11-2014, 10:16 PM   #7
Rewards Points: 39
scratch coat mortar over 3/8 plywood.
Old 03-11-2014, 10:34 PM   #8
Rewards Points: 39
every tile i pull up all the mortar is on the floor and very little bondin to the tile? Are these types of mesh bacj tiles prone to this? I've nevr had this problem before?
Old 03-11-2014, 11:09 PM   #9
Rewards Points: 12,794
Wrong mortar and never should have been installed over just plywood.
Old 03-11-2014, 11:30 PM   #10
Tileguy
JazMan's Avatar
Rewards Points: 214
Scratch coat over ply? Yikes. What's under the 3/8" ply?
Where are you, Canada or East Coast?
Jaz
Tags
floor , mortar , tile
Tile backsplash with marble and glass mosaic ponch37300 Tiling, ceramics, marble 13 05-02-2013 09:38 AM
very small mosaic marble tiles, no grout? yummy mummy Tiling, ceramics, marble 8 01-11-2012 07:39 PM
heating small bathroom floor - maybe rtoni Flooring 0 09-22-2010 04:11 PM
Curved Small Stage jalaux Carpentry 1 07-09-2006 10:57 PM
