Old 01-02-2012, 11:06 AM   #1
small low spot in subfloor
I am getting ready to lay laminate in my living room (15' x 20'). The living room is an addition to a 1940's built home. Currently ther is carpet and I can feel a dip in the trasisition between the addition and main structure. What is the best product to use to to level this up before install?
mwmonty is offline   Reply With Quote
Old 01-02-2012, 11:16 AM   #2
Tar paper, non gypsom floor levler, your choise.
Old 01-02-2012, 12:30 PM   #3
Disabled wood vet
titanoman's Avatar
If it's 1/4l", you can lay down underlayment or paneling.
Sent from a Samsung Galaxy S2
titanoman is offline   Reply With Quote
Old 01-02-2012, 12:56 PM   #4
Tileguy
JazMan's Avatar
Use a Portland patching material. There are many brands such as Ardex, Henry, Durabond, etc. Just nothing premixed.
Jaz
Tile 4 You LLC Troy, MI
KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME!
Old 01-02-2012, 01:00 PM   #5
The problum with a piece of 1/4 anything is all you have done is move the step further out, It needs to be a gadual step down. Floor levler with a 2 X 4 used as a screed will give you the taper you need.
Old 01-02-2012, 01:22 PM   #6
Disabled wood vet
titanoman's Avatar
Oh. I thought it was a consistent difference, starting at the transitions.
Old 01-02-2012, 01:24 PM   #7
Thanks, I have two weeks until I will be doing install. I will pull up the carpet next weekend to see what I am dealing with level wise.
Tags
laminate floor, leveling problems
Prep for tile in a small foyer Nick DIY Flooring 1 12-09-2010 07:40 PM
Would you replace this subfloor? winterminute Flooring 2 11-30-2010 11:48 AM
Replacing damaged subfloor - Help!! Michelle D Building & Construction 1 07-30-2010 12:47 AM
Kitchen subfloor questions tishimself Tiling, ceramics, marble 7 12-09-2008 10:16 AM
Replaced section of subfloor but it's 1/16" higher. Is that a prob? Piedmont Carpentry 1 08-29-2008 11:12 AM
