-   -   small low spot in subfloor (http://www.diychatroom.com/f5/small-low-spot-subfloor-128505/)
mwmonty 01-02-2012 10:06 AM
I am getting ready to lay laminate in my living room (15' x 20'). The living room is an addition to a 1940's built home. Currently ther is carpet and I can feel a dip in the trasisition between the addition and main structure. What is the best product to use to to level this up before install?
joecaption 01-02-2012 10:16 AM
Tar paper, non gypsom floor levler, your choise.
titanoman 01-02-2012 11:30 AM
If it's 1/4l", you can lay down underlayment or paneling.
Sent from a Samsung Galaxy S2
JazMan 01-02-2012 11:56 AM
Use a Portland patching material. There are many brands such as Ardex, Henry, Durabond, etc. Just nothing premixed.
Jaz
joecaption 01-02-2012 12:00 PM
The problum with a piece of 1/4 anything is all you have done is move the step further out, It needs to be a gadual step down. Floor levler with a 2 X 4 used as a screed will give you the taper you need.
titanoman 01-02-2012 12:22 PM
Oh. I thought it was a consistent difference, starting at the transitions.
mwmonty 01-02-2012 12:24 PM
Thanks, I have two weeks until I will be doing install. I will pull up the carpet next weekend to see what I am dealing with level wise.
