Old 01-12-2011, 01:06 PM   #1
slippery tiles, help needed
hello,
what can i put on the outside front tile floor, it's very slippery when it wet or dried. the tiles are new
thank you
idalia is offline   Reply With Quote
Old 01-12-2011, 01:11 PM   #2
the Musigician
DangerMouse's Avatar
Hello and welcome to the forum.
I moved your question to the flooring section. You'll get an answer here much faster.
Guys? Ideas?
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
The Following User Says Thank You to DangerMouse For This Useful Post:
idalia (01-12-2011)
Old 01-12-2011, 01:15 PM   #3
Hello,my entry floor have tile and very slippery what can i put on the tile.need your help.i already slipp.
thank you
Old 01-12-2011, 01:38 PM   #4
the Musigician
Perhaps a rubber-bottomed (so it doesn't slide around) throw rug would help?
That's a pretty cheap solution.
DM
Old 01-12-2011, 01:53 PM   #5
Here you go: http://www.harrisind.com/ns.htm you have to use non slip tape
epson is offline   Reply With Quote
Laying Subfloor for New Bathroom Question rjschwar Kitchen & Bath Remodeling 3 06-25-2010 04:06 PM
loose tiles in bathroom exodus125 Tiling, ceramics, marble 1 05-10-2010 08:43 PM
Old Tiles Removed - Now What?!?! Pineapple Flooring 5 10-14-2008 01:02 AM
Will vinyl tiles stick to this? rebekkah Flooring 1 01-12-2008 02:04 AM
How do you Lay Large Tiles over Plywood Subfloor? 1655graff Flooring 20 10-01-2007 06:28 PM
