Sliding Closet Door Track
The associate was wrong. Laminate flooring expands equally in all directions. You have a track on the floor or just guides? You could just go up to the door and use a transition piece. The laminate flooring will have accessories such as baseboard, quarter round, and transition pieces. You could also just silicone or epoxy to the surface with your guides and tracking. There won't be enough movement to mess with your door and it will allow for the expansion and contraction needed.
Josh Jaros Remodeling in The Woodlands, Texas To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
