SLC Gone Bad - Flooring - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 01:18 PM   #1
SLC gone bad
Working on my 7x6 bathroom that had a few low areas. The floor is a concrete slab. Originally there was tile glued to the floor. I cleaned the floor up really well prior to work today. I plan to tile with ceramic when floor is ready.
I applied the primer and allowed to dry to tacky per directions. I mixed up a bag of DAP brand self-leveling mix- mostly portland cementl. I made it the suggested consistency which was milkshake. I poured it over the slight dips first and anticipated seeing it slowly more out and self level. It did nothing. I troweled it but even my trowel lines are present. It's more bumpy now than before.
I added more water than the directions stated but feel it was not liquid enough.
So can I make another batch using more water to make it runnier and pour it over or should I scrap up the first layer and start over?
aechabot is offline   Reply With Quote
Old 08-06-2012, 01:48 PM   #2
Rewards Points: 14,290
Originally Posted by aechabot View Post
Working on my 7x6 bathroom that had a few low areas. Originally there was tile glues to the flood. I cleaned the floor up really well prior to work today. I plan to tile with ceramic when floor is ready.
I applies the primer and allowed to dry to tacky per directions. I mixed up a bag of Ace brand self-leveling mix- mostly gypsum I recall. I made it the suggested consistency which was milkshake. I poured it over the slight dips first and anticipated seeing it slowly more out and self level. It did nothing. I troweled it but even my trowel lines are present. It's more bumpy now than before.
So can I make another batch that is juicier and pour it over or should I scrap up the first layer and start over?
Your post is a little confusing to me so I have some questions.
For this to work out there's something people here are going to need to know.
What on the floor now for subflooring and underlayment.
That's the floor joist widths and spans.
Just how far out is the floor now.
Not using any tile board underlamant?
What do you mean by a flood?
Old 08-06-2012, 01:52 PM   #3
edited for clarity
i hope this clears things up. Thanks
the floor is level from wall to wall but there are some areas where there are "dips" i guess you caould say. I'd put my 48' level across the floor and parts of the floor did not touch the bottom of the level. It's not more than 1/8th inch. But the tile store told me the floor had to be completely level before they could install.
Old 08-06-2012, 01:58 PM   #4
Amateuralex's Avatar
Rewards Points: 270
Most SLC won't function below 1/8 inch. It should say so on the package.
Amateuralex is offline   Reply With Quote
Old 08-06-2012, 02:28 PM   #5
So can I build up the thin set enough to level the tiles?
If its 1/8 over the entire floor- these areas will be a little deeper so everything is level.
Old 08-06-2012, 02:32 PM   #6
Rewards Points: 270
I've seen it recommended to use thinset like this, and I did and it worked for me, but I can't say what official, to-code advice would be. It's certainly easy. I did it 24 hours before I laid the tile so the thinset I used to raise areas had plenty of time to dry.
Old 08-06-2012, 02:46 PM   #7
what was under the tile you ripped out? what kind of tile was it, ceramic, vinyl squares? was there 1/4 inch underlayment under it?
Old 08-06-2012, 02:54 PM   #8
Two inch ceramic tiles glued to concrete slab
Old 08-07-2012, 08:35 AM   #9
if you are having this done by a "tile shop" then they should be prepping the floor for "their" install.
if anything happens to the tile down the road they will say it wasn't prepped right.
