SLC Between Layers Of Plywood??? - Flooring - DIY Chatroom Home Improvement Forum
Old 08-31-2008, 04:06 PM   #1
Insulation/Soundproofing
SLC between layers of plywood???
Hi, Thanks to my good friends at the CRAP Depot, I just installed a new subfloor with two different thicknesses of plywood. Only off by about 1/16". Just enough to p*** me off! Seeing that there are a few other dips in the floor, I was planning on leveling it later. However, in my last post, I was informed that I should add a second layer of plywood. Now its time to do that. I was wondering what I could use to level the floor before I put down the second layer of ply? Can I use SLC? Will this bond to the plywoods? Maybe joint compound? Now there's a crazy idea that I just thought of! Any help would be great! Thanks!
MIKE
insulatorpro is offline   Reply With Quote
Old 08-31-2008, 04:42 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK now I am beginning to wonder about you. Also, why did you jump the track and start another thread? Now no one has any idea what the hell you are talking about now.
OH, by-the-way, no way you can do what you are suggesting here. Forget that crazy idea.
Old 08-31-2008, 05:09 PM   #3
Posted new thread due to switching of subject from wall to floor. I guess I could have put it under my floor post. Anyway, the floor is pretty uneven where different thickness of plywood butt up to each other. New 1/2" ply has a little movement. Can't I level it out a little bit with something that will "hold up?
Old 08-31-2008, 08:21 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes, but on top, not in between the plywood sheets.
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
Removing kitchen tile with plywood under it ediconu Flooring 4 08-26-2007 09:48 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
Renovating: 2 layers of Plywood Necessary for ? harleysilo Flooring 2 06-20-2006 11:14 PM
