Slate Tiles On Floor And Walls - Flooring - DIY Chatroom Home Improvement Forum
Old 04-06-2008, 03:00 PM   #1
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
Slate tiles on floor and walls
I have a small 5' x 7' half bath on my first floor. I have always loved the look of slate, so was planning to do slate in there. i have a couple questions
if i do the walls also, will it be too dark and overwhelming in such a small space?
what size tiles do you reccommend? I've always heard small tiles for small spaces, so is that 6 x 6 ? do you use different size on walls?
How high up the wall do you go? I was thinking to just under the window.
I know a lot of this comes down to personal taste, but if i do all this work ( and spend all this $$) and don't like the result I'll be stuck living with it for a while, so any input will be greatly appreciated.
Mr Chips is offline   Reply With Quote
Old 04-07-2008, 02:38 AM   #2
Floorwizard's Avatar
that size bath you would be taking a risk unless you pick out a lighter Slate. 12X12 floor with 6x6 wall and incorporate some diagonals...
That would be nice-
Floorwizard is offline   Reply With Quote
Old 04-07-2008, 07:34 AM   #3
Tile and Paint contractor
If you were gonna go up the walls. Just a wainscotting level would look good. You can top this with a chair rail or listello. You could still use 12" tile throughout.
What's the dimensions of your room?
Can you give me a sketch or blueprint?
I'll draw a 3D mockup of the two sizes in Sketchup for you so you can get an idea of how it will look.
Matt | tile contractor
Charlotte, NC
MattCoops is offline   Reply With Quote
Old 04-07-2008, 06:29 PM   #4
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
North and south wall are 5' wide. East and west are 7' long. North wall has a window in center. south wall has the entrance door, almost all the way on the western side. Eastern wall has sink and toilet. sink near the door, toilet near window.
hope this makes sense
Old 04-07-2008, 06:47 PM   #5
How far up from the floor is the bottom of the window trim (ft and inches)?
Charlotte, NC
Old 04-07-2008, 09:47 PM   #6
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
window trim sits 3' 10" of floor and 12" frow either wall
Old 04-08-2008, 05:21 PM   #7
tile designs
Here's some rough tile designs I did in Sketchup for your bath with your dimensions.
  • 12" floor and wall (which I like best; and would be easiest to do)
  • 12" floor and 6" wall
  • 6" floor and wall
Charlotte, NC
Old 04-08-2008, 09:36 PM   #8
DIY Hack
Mr Chips's Avatar
Rewards Points: 506
thanks!! i really appreciate your taking the time to do this!!
i agree that the 12 x12 look best
you rock
Chips
Old 04-09-2008, 06:49 PM   #9
Advice worth 2 cents!
Rewards Points: 150
Just make sure your sub floor can handle the weight of those tiles! Any deflection is going to be disaster!!! Minimum is 2 layers of exterior grade ply with a 3/4" on the first layer!
- pete
---pete
HandyPete is offline   Reply With Quote
