Slate Tile On An Uneven Floor - Flooring - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 01:29 PM   #1
Slate tile on an uneven floor
I have an 80 year old house and decided to renovate the bathroom. I ended up taking the floor right down to the 3/4" plank subfloor. One of the joists is higher and twisted therefore giving a bulge in the subfloor. From the highest point over to where the toilet is, it is out by an inch. If I raise that area the phlange of the toilet will be too low. What to do?
AngieR. is offline   Reply With Quote
Old 01-29-2011, 05:35 PM   #2
woodman58's Avatar
Cut the section of floor out from the joists on both sides of the high joist. Use a hand plan and plan down the high joist. ( I prefer a power planer. Box srore $35) You may need a chiselthe ends where the plan won't reach. Put a straight edge accross the joist to make sure there the same hight. Then put the wood you cut out back in or replace with new wood of the same thickness.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
unlvrebel (02-11-2011)
Installing vinyl plank over existing, uneven floor? AKCDIY Flooring 5 11-01-2014 04:48 PM
HELP! with brick tile floor cpmathis Flooring 0 09-03-2010 10:58 AM
Tile over Tile over Slate - can slate be salvaged? jwilds1 Flooring 0 11-17-2009 03:27 PM
Busting out my shower tile floor and walls. caliskier Building & Construction 3 03-15-2009 08:59 AM
what sub floor for slate tile? gk02 Flooring 10 02-26-2009 09:49 AM
