Slate Flooring - Flooring - DIY Chatroom Home Improvement Forum
Old 01-29-2011, 12:45 PM   #1
Slate flooring
We have slate flooring starting at the front entry and extending down a hall and into the kitchen. This floor is very uneven throughout and has become dangerous to walk on because of the differences in thickness of tiles, almost 1/2 inch in places, and deep holes. I can't use a sponge mop because it disinegrates, and I can't use my vacuum either. We're wondering if there is anything we can do to cover this floor with a thin layer of concrete to smooth it out and cover it? We absolutely hate it, but can't afford to have it taken out. It is installed over pre-stress concrete and using a jack hammer to remove it is out of the question. It is a loft unit. Suggestions would be greatly appreciated.
beachwalker is offline   Reply With Quote
Old 01-29-2011, 06:47 PM   #2
woodman58's Avatar
You can use a self leveling floor leveler. Instead of adding water, use a liquid latex additive. Do this in stages and let it set up before putting the next coat on. Use the flat side of the trowel to level. When you think it is level then go over the whole floor with a scim coat. Then you can put any floor over this. If you put carpet down you will need to drill the tack strip to the floor.
woodman58 is offline   Reply With Quote
The Following User Says Thank You to woodman58 For This Useful Post:
beachwalker (01-29-2011)
Old 01-29-2011, 07:30 PM   #3
Slate floor fix
Woodman58, thank you so much for your input. When the time comes we will contact a flooring expert and see if we can use this fix. will let you know!
beachwalker
Old 01-29-2011, 08:24 PM   #4
Contractor - Renovations
fungku's Avatar
talk to someone who does concrete toppings for a living.
if you use a self-leveller and then flooring over it, you increasing the height of your floor by at least 1/2"... check door sills, and anything else around that may be effected by this.
fungku is offline   Reply With Quote
The Following User Says Thank You to fungku For This Useful Post:
Old 01-31-2011, 06:13 PM   #5
woodman58's Avatar
True the tile can come up easy. But, Thinset does not come off easy if it was mixed properly.
beachwalker (01-31-2011)
Old 02-11-2011, 01:46 PM   #6
Another possible solution... For the tile to tile joints that have large changes in height, take a cold chisel and a hammer and slowly chip it away until the floor moves closer to "flat". Then take a palm samder with very aggressive sandpaper, say 60 grit, and sand the floor. Slate is very soft and sands relatively easy. Another alternative is to use an angle grinder and a diamond cup to hit all the high spots and then sand. Point is, there are other alternatives that allow you to keep the floor. For the areas that are severly depressed about all you can do is sand it smooth. As for mopping, use a cotton mop, not a cellulose mop.
unlvrebel is offline   Reply With Quote
The Following User Says Thank You to unlvrebel For This Useful Post:
beachwalker (02-11-2011)
Non square slate tile flooring JakAHearts Flooring 6 04-22-2010 03:44 PM
DESPERATELY Need Pergo Paradigm Grey Slate laminate flooring Mariodii Flooring 1 07-01-2008 09:26 AM
Laminate timber flooring over exsisting slate scott10 Flooring 6 06-20-2008 05:04 PM
marble tile over existing slate and concrete flooring bullrage22 Flooring 13 05-19-2008 08:58 PM
Slate Flooring...Problems Encountered djchrishart Flooring 1 12-12-2007 12:13 PM
