Slate Floor Help - Flooring - DIY Chatroom Home Improvement Forum
Old 05-04-2013, 01:04 PM   #1
Rewards Points: 91
slate floor help
Looking for some quick help - I'm trying to refinish a slate floor before I have surrounding hardwood refinished on Monday!
The existing slate was installed in 1959, and has been coated with something that doesn't look good - see pic:
suspecting wax, i went to home depot and from their stone section bought an abrasive stipper that was ok for natural stone. I followed the instructions, and tried a 2sqft area, scrubbing with a nylon abrasive pad. Nothing happened. I let the liquid set for a while and tried again. Nothing - nothing at all. In frustration i picked up my putty knife and scratched at it - immediately, the top coat gave way. I then tried it on a dry area, and it gave way too there. It didn't seem to scratch the slate underneath.
Trouble is, i've got about 100sqft of this, and can't use the putty knife on all of it! What do i do? My local Home depot has those floor scrubbing things for rent - do i get one with a really appressive real and just whirl it on dry?
Any help greatly appreciated!!!!
thanks,
Matt
mmhendrie is offline   Reply With Quote
Old 05-05-2013, 08:50 PM   #2
Rewards Points: 160
Attachment 70317
thanks,
Matt
Beautiful floor and I agree the coating sucks. Problem with slate (and many other stones) is that they absorb huge amounts of water unless sealed very well. But the good commercial sealers available today don't produce that waxy finish that I see in your photo.
Do you have a tile store in your town? if so, try asking them what to do. Talk to the manager if possible, rather than the sales folks (though the good ones will either know or escalate up to someone who does.) They will know xxx times what you can find out at HD or Lowe's and will continue to help you forever. Try several. Free advice is cheap, though it requires sifting.
Good luck and tell us if you find a solution.
Wish I could help you but...
philS is offline   Reply With Quote
Old 05-05-2013, 08:58 PM   #3
DIY staff
Rewards Points: 7,174
Try this as an experiment----soak a bath towel in hot ammonia water mix----
Lay that on the stone and leave it for a while---see if that lifts the old coating---
I've done it on an old slate floor and the years of wax came loose---I used old bed sheets as the area was large---
Need help to repair slate wall cap Rav Concrete, Stone & Masonry 3 03-21-2013 08:08 PM
slate walls timbo59 Building & Construction 5 12-06-2010 09:46 AM
Plasma TV over Slate jrcrum Home Theater 8 12-16-2009 04:59 PM
Tile over Tile over Slate - can slate be salvaged? jwilds1 Flooring 0 11-17-2009 03:27 PM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 04:23 PM
