Old 01-29-2007, 08:28 PM   #1
Default Slate Floor
The foyer of the house we just bought has a slate floor. The floor is very dirt from years of traffic and missing some grout.
What is the best way to clean a slate floor? They previous owners must have had a mat on it as there is residue from a mat that needs to be removed. What cleaners do you recommend?
As for the missing grout, I can fill in the little sections but that will probably leave difference in the color between the old grout and new grout. Any tips for getting them to match or should I try to get all the old grout out (doesn't look easy as most is in pretty good shape)>
Thanks in advance for replies.
Mike
mruggeri001 is offline   Reply With Quote
Old 02-01-2007, 01:59 PM   #2
Counter top cleaners generally work well on porous stone. If not there are acids on the market which should only be handled by pros. In order to get the grout to match you will likely have to do the entire surface. A grout saw works well for removal. Use a good sealer usually found in counter top area of your home center.
shawnplr is offline   Reply With Quote
Old 02-01-2007, 06:12 PM   #3
leftoverjoe's Avatar
We are finishing off the install of a new slate tile floor in our master bathroom. I've heard that Aqua Mix products are pretty good. They have sealers, cleaners, and other products all for stone, slate, tiles, etc. Slate looks great, but it definitely needs maintenance in those high-traffic areas. I am going to be putting three coats of sealer/enhancer down first, then grouting, then adding at least one coat of grout sealer.
leftoverjoe is offline   Reply With Quote
Old 02-04-2007, 03:29 PM   #4
Tileguy
A-h-h-h-h- THE OLD ACID TRICK.
Acids are so misunderstood and in some cases dangerous to use and yet people continue to suggest acids without knowing a damned thing about them.
Acids that would be used to address issues with masonry products WILL NOT HAVE ANY EFFECT ON DIRT. That's not how acids work.
Use any houshold cleaner to clean the tiles. I would suggest Spic-N-Span.
Then the grout is another issue. If grout is cracking in areas then there is a problem with either loose tiles or structural movement. In either case simply regrouting WILL NOT resolve the issue for very long. The grout will crack again.
Should you decide to regrout and live with the expectation of doing it again down the road then remove all the grout and start over. Using a modified grout will help expand the life of the grout to a small degree.
Aqua-Mix products are top-o-the-line products.
Once the tile is cleaned and the new grout is in place then seal everything abundantly with a stone sealer such as Aqua-Mix.
The thing to do is to get to the bottom of what is really destroying the grout. Are there loose tiles also? Is this a wood or concrete floor under the tile?
More On This Topic
I’m Lee; I have a degree in architecture and about ten year experience in the construction field, and we’ve just finished, yesterday, grouting our designer countertop. I’ve already wiped this one down. You just want to take a sponge and... Read More »
Hi! This is Steven from Keilholz Flooring on behalf of Expertvillage.com and in this segment, I am going to show you how to apply a grout and talk about grout a little bit. There are three separate kinds of grout. There is a sandy grout, non-sandy grout... Read More »
How to Seal Tile
How to Seal Tile by Expert Village
I’m Lee; I have a degree in architecture and about ten years experience in the construction field, and have been installing designer countertops today. After you have gotten the tile down to the countertop, you want to go ahead and seal it. A lot... Read More »
I’m Lee, I have a degree in architecture and about ten years experience in the construction field. Today we have been installing a designer counter top and we’re ready to grout it. You just want to buy the grout color of your choice- we’... Read More »
Tiled counter tops are very classy looking until the grout joints get stained or begin to loosen. You can save the expense of replacing the counter with just a little work. Re-grout the tile on your counter by following the steps and tips below. Read More »
Slate Floor Electric Underfloor Heating Lottie Flooring 4 09-22-2008 10:03 AM
Floor joists for 2nd Floor Addition poptop Building & Construction 4 01-11-2008 09:57 PM
old uneven bathroom floor toubob Flooring 4 02-15-2007 03:39 PM
retoring slate floor stanleymanley Flooring 1 01-27-2007 04:38 PM
Advice and help on slate floors adamsela Flooring 1 10-04-2006 06:23 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
