Slab Floor Leveling. - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 08:48 PM   #16
Tileguy
JazMan's Avatar
Rewards Points: 220
I used sand topping and it lifted and stepping on it made it snap off easily...like walkindlg on big potato chips for lack of a better description.
Well yea, I thought why that happened was answered in post #6.
it is necessary to "bond" to the slab.
I'm wonder why the rest of it is still there. You said it won't come up. It somehow stuck, or it may be because it's thicker...heavier.
If you only need 3 bags to finish, that's what I would do, cheap enough, no?
Jaz
Old 02-27-2012, 06:51 PM   #17
Rewards Points: 212
Jaz
I'm on my sixth bag of levelor... I could have stopped at 4 for carpet but going for "glue down carpet squares" which i imagine cant seem over rough edges.
Yes, Jazman, the center of the whole floor patch was thicker and seemed to be so massive, it will never move...putting levelor around the edges made it solid with no more hollow noise...sounded hollow because cement shrunk a little an 1/8 inch underneath.
Can't thank you enough for hangin' in there with me Jazman, and other moderators too, thank you very much!
Squeakyhinge is offline   Reply With Quote
Extending Patio Slab and adding a cover Jeoroc24 Building & Construction 5 04-12-2011 12:16 PM
raised slab foundation tclark Building & Construction 6 01-07-2011 09:10 AM
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 01:23 PM
Filling hole in carport (concrete slab) chaddihimself Building & Construction 2 08-10-2007 01:50 PM
