Size Of Laminate Layout Before T-joints Are Needed - Flooring - DIY Chatroom Home Improvement Forum
Old 06-22-2006, 11:08 AM   #1
Size of laminate layout before t-joints are needed
Hi,
I'm having laminate flooring installed in my basement (below grade) and was told that "baby t-joint" have to be used at every doorway as the floor area is too big. The total square footage is around 1000. I'm concerned because the joints doesn't make the floor look as nice and it also divide up the area and make it look smaller. My question is, how big an area before joints are needed (for expansion)? I'm thinking that the contractor may be trying to cutting corner as it is easier to just put a t-joint at the door than to lay it all the way out. Also have anyone heard of the brand QuickStep? How is the quality? Please advise.
Thank you.
Wing
wingman is offline   Reply With Quote
Old 06-22-2006, 10:42 PM   #2
Floorwizard's Avatar
30 feet long in a big room is the general rule.
It is always good to use t moldings in doorways because it helps the floor expand and contract seperately, although it is not always a NEED.
Floorwizard is offline   Reply With Quote
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
laminate install diyjoe Flooring 15 11-23-2007 03:49 AM
Mixing Hardwood, Carpet, and Laminate! reptilicus81 Flooring 3 11-25-2006 09:43 PM
