#16 | |
Shower tiles fell off, water damaged wallQuote:
Thanks Jaz, I can see you are really good at this stuff! I really like the tip of caulking around the perimeter, I never would have thought of that. I would remove more tiles but every tile I remove takes the wallboard with it and in pieces. But what do you mean by glue the edges so it'll bond to the old wallboard? Do I just use mastic? |
#17 | |
Tileguy
![]() Use a 4" tapered putty knife and tap tap with a hammer slicing the tiles off. Should be minimal damage unless the board is weak. By gluing the edges, I meant the edges of the new and old board, glue them together. But if you remove more tiles you will be able to apply fiberglass mesh tape and thinset to create a monolithic base. That's the best way. Do not use drywall compound or anything made with gypsum. Use the thinset or mastic if you were going that way. Jaz
Tile 4 You LLC Troy, MI KERDI Shower Specialist ... DITRA Installs ... Product-Method suitability consultation. I have NEVER made a mistake, I thought I did once...........but I was wrong! - PRODUCTS ADVERTISED WITHIN MY POST ARE NOT ENDORSED BY ME! |
| Display Modes | |
| No water in shower and Im out of things to try | loki993 | Plumbing | 29 | 11-28-2012 08:13 AM |
| Tiled Shower Repair Help, Please | Unicornz0 | Plumbing | 2 | 09-16-2012 10:22 PM |
| Mastic for shower wall tiles | ashton44 | Tiling, ceramics, marble | 2 | 05-07-2012 09:32 PM |
| Potential Water Issue in New Shower? | cobrakai | Kitchen & Bath Remodeling | 4 | 02-12-2011 06:36 PM |
| outside wall heavily water damaged, how to dry? | scottlindner | General Discussion | 5 | 01-04-2006 07:51 PM |
