Shower Stall Installation - Flooring - DIY Chatroom Home Improvement Forum
Old 04-03-2011, 09:31 PM   #1
Shower stall installation
I am rebuilding a bathroom with shower stall and I'm a bit unsure of the steps to complete, in which order. The shower stall is a corner unit with glass walls and door, and I intend to greenboard the walls and put down vinyl flooring.
The instructions that came with the shower aren't clear - should I put down the vinyl before the shower pan, or the other way around? If it's shower before vinyl, can the shower rest on the subfloor, or should it sit on the 1/4" plywood underlay that I will be putting down. It's a simple rectangular room with basic bathroom floor cut-outs in the vinyl. Further, does the greenboard behind the shower have to be mudded/taped and painted before I install the shower walls?
Any help is appreciated!
mforeman1 is offline   Reply With Quote
Old 04-06-2011, 07:39 AM   #2
Rewards Points: 5,336
Usually the floor is butted up to the tub or shower and the interface is sealed so water can't get in.
But there's no reason you can't run it under the base. You just need to support the base evenly all around.
Advice about framing for a shower stall Tooncie Building & Construction 1 08-27-2010 08:54 PM
drywall in shower stall bikswahla Drywall & Plaster 21 05-18-2010 03:36 PM
Shower stall size? sharp Remodeling 1 01-21-2010 10:38 PM
Possible to coat or seal a tile floor in a stall shower? Jeff DIY Kitchen & Bath Remodeling 8 08-28-2009 06:51 AM
Shower installation help needed neonrider General DIY Discussions 1 08-24-2005 05:15 PM
