Old 02-25-2012, 04:24 PM   #1
Shower Pan Tiling
We are in the middle of renovating our bathroom. We have chosen pebble tile for the shower pan and am uncertain whether to tile the shower pan first or tile the walls.
We are using large format porcelain tile on the walls.
Is it it better to cut the wall tile when the floor pebbles are in place OR to tile the wall down to the pan and then install the floor pebbles?
HeidiT is offline   Reply With Quote
Old 02-25-2012, 04:30 PM   #2
Shower Pan Tiling
Pan first so the wall tile will stick out past the pan tile.
HeidiT (02-25-2012)
Old 02-25-2012, 07:20 PM   #3
Super Moderator
Shower Pan Tiling
Most tile setters use a ledger board to hold up the second course of wall tile---leaving out the bottom course until after the walls are complete---
If you are using that method----tile upper walls first---then the pan--then the bottom course of tiles-
Saves you from working over the newly laid pan tiles----
By the way----pebble tiles are troublesome--the uneven random sizes cause drainage problems---leaving lots of soap scum to build up in the grout---most people hate it--complain about the look--and often rip out the pan tiles and replace them---
Just thought you aught to know.---Mike---
HeidiT (02-25-2012)
Bathtub/ shower tiling buju Tiling, ceramics, marble 37 08-07-2012 08:03 PM
Tiling shower wall valentin46 Carpentry 3 05-30-2011 07:54 AM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 07:33 AM
Tiling over greenboard outside shower area toocheaptohire Remodeling 4 04-10-2009 09:42 AM
Tiling over plastic shower base newproject Building & Construction 5 02-21-2009 08:40 PM
