Shower Leaking Need To Re Tile - Flooring - Page 4 - DIY Chatroom Home Improvement Forum
Old 07-25-2009, 07:36 PM   #46
Tileguy
Bud Cline's Avatar
Rewards Points: 558
If all you intend to do is band-aide the receptor (area) and not fuss with the existing walls then the KERDI method is a lot easier to do and is actually your best bet. It would save a lot of frustration.
Old 07-25-2009, 09:22 PM   #47
WHat do you mean band aide... should i remove more of the walls? I like the kerdi method but the mortar to connect it scares me! I found a sheet of liner at HD 5x6' That should cover whole shower in one piece.
I am missing something how is it easier?
Ineedhelp2009 is offline   Reply With Quote
Old 07-25-2009, 10:22 PM   #48
Tileguy
Bud Cline's Avatar
Rewards Points: 558
It is easier because you don't have to cast a preslope and then a top slope.
It is easier because you don't have to wrestle the thick liner into the corners.
It is easier because you don't have to find an alternate means of waterproofing the bench.
It is easier because you don't have weep holes to become blocked in the future.
It is easier because you don't have to figure out how to attach the short wallboard without penetrating the liner now that you are abbreviating the wall repairs.
It is easier just because it is easier.
And who are you? Millions of square feet of KERDI in service in the last decade and little ole YOU is challenging the seaming method??? Let's move on.
Old 07-25-2009, 10:34 PM   #49
Sold!
How far would you recommend going up the walls? How much more tile should I remove?
Old 07-25-2009, 10:47 PM   #50
http://www.schluter.com/media/brochu...ndbook2008.pdf
Old 07-26-2009, 11:19 AM   #51
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I suppose if you aren't going to do the whole thing over, then maybe 16 to 18 inches up from the floor is a somewhat safe bet.
You should probably use a decorative liner at the point on/up the wall where the new tile stops. This will help to disguise the subsurface variation you are going to have.
Old 07-26-2009, 12:43 PM   #52
Thanks, will return other stuff
Old 07-26-2009, 01:50 PM   #53
i did find the wall tile.... outside the floor i was able to tear 15 tiles out and only breaking 2 Just doing a new shower floor.......
Old 07-26-2009, 02:07 PM   #54
Tileguy
Bud Cline's Avatar
Rewards Points: 558
That link gets me no where. It says the product isn't currently available in the store I am browsing and to try a different location. It doesn't tell me what the product is. I hate HD's website! You do it their way or you don't do it.
Old 07-26-2009, 02:11 PM   #55
How important is the $120 kerdi drain? I have seen installs with and without....
Old 07-26-2009, 02:17 PM   #56
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Did you buy KERDI Mat or DITRA?
Old 07-26-2009, 02:30 PM   #57
is the kerdi drain....must buy?
Old 07-26-2009, 04:18 PM   #58
I see kerdi for shower, and ditra for regular floors...
Old 07-27-2009, 08:56 AM   #59
What do you think about the Kerdi shower tray?
Old 07-27-2009, 11:49 AM   #60
Better yet....thinking about the whole ....Kerdi kit.......pan, membrane, and drain... in case i do mess up the mortar slope.
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 03:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
