Shower Leaking Need To Re Tile - Flooring - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-22-2009, 04:22 PM   #31
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Return one of the jet skis!
OK OK OK, sorry 'bout that. It was just an idea. They can't all be good ones ya know!
Old 07-22-2009, 05:55 PM   #32
I hear ya, Figure someone would let me have it that's the family fun........
Ineedhelp2009 is offline   Reply With Quote
Old 07-22-2009, 05:57 PM   #33
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Horse shoes are cheaper, how about Scrabble?
Old 07-22-2009, 06:13 PM   #34
Got a really good deal on them
Old 07-22-2009, 06:52 PM   #35
Depends on the area that you live in and what you end up picking for tile. Will there be a new door? You're going to need to do some plumbing. Install new fixtures. Which kind and brand? Probably going to need to rip out some insulation? Figure in painting the whole bathroom with a new coat of paint. Lots to consider before ball parking a figure without visiting the jobsite. If you can't save for the job, credit isn't a bad idea. If you can pay it off within a reasonable amount of time and the extra load won't hurt you.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-22-2009, 07:18 PM   #36
I hear ya... plumbing I have the body sprayer junk in there.... Well my plan is to sell my "in case **** happens items"
Old 07-23-2009, 10:05 AM   #37
Chicago, IL
Michael Thomas's Avatar
Ineedhelp2009,
Check your in box (upper right corner of this screen) for a PM.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 07-23-2009, 10:50 PM   #38
Originally Posted by Michael Thomas View Post
Ineedhelp2009,
8014373200181 is the upc number on the back of the tile I am in need of if anyone knows where to puchase. Originally from HD.
plus updated pictures will post as I go, from what i gather shower only leaking around door area.. see rotten wood. The other sides have been dry as can be behind the cement board. I have peeled some parts of liner and wood is dry underneath. Will post more pictures as I remove floor.
Jaros from What i have seen there is no membrane at all (see picture 3).....just board mortar then tile.
Look at pic #2 no protection on the small 2x4 that looks like it was used as a spacer.... Tile was directly on top. Water hit that area daily!
Old 07-24-2009, 09:20 PM   #39
Are the nails suppose to be this low? Other then that and the corners by door, i see no problems do you? Is the drain done right?
Old 07-25-2009, 11:45 AM   #40
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No-way. Had a hunch that would be the problem when I made my post back at #11. I love it when I'm right!
Old 07-25-2009, 12:10 PM   #41
HAHA good eye... i pulled the rest of liner out... everything is good but the door area. the step going in shower was 2x6's sitting side ways... Considering the amount of mold outside the shower from water splash, i was thinking of building wall higher.. maybe 2x8 or 10 what do you think?
Still want to provide that good write up on doing the pan..... HD just sent me a 20% off $600 purchase
Plan on tearing out the seat and doing something different as well any idea's?
Old 07-25-2009, 03:43 PM   #42
Tileguy
Bud Cline's Avatar
Rewards Points: 558
No real need to do that. Showers using 2x wood for a curb is generally three or four 2 X 4's stacked and waterproofed, this has always been sufficient. This method gives you a nominal 6" on the outside of the shower and a nominal 3" on the inside. Of course your shower curtain must stay inside the curb or your shower door must fit properly.
Here’s the scoop on a conventional-build such as what you have now:
http://www.ontariotile.com/preslope.html
Here’s the method I would recommend, this is state of the art right now:
http://www.ontariotile.com/kerdi-shower3.html
Roam around Harry's website there's a lot to learn there. Harry is in Canada where the techinques are basically the same as the U.S. and Harry has been generous enough to offer plenty of good information on his website.
Old 07-25-2009, 03:50 PM   #43
Thanks again! no curtain just door and my wife leaves cracked open that helped alot of water outside the door i believe
Old 07-25-2009, 04:05 PM   #44
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK "wifey", that'll be enough of that stuff. THAT'S ONE!!!
Keep it up and there'll be no jet ski in your future.
Old 07-25-2009, 07:06 PM   #45
I hear ya... again thanks for the advice will use the liner since i am not removing all the tile. Will post more pictures...
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 03:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
