Shower Leaking Need To Re Tile - Flooring - Page 2 - DIY Chatroom Home Improvement Forum
Old 07-20-2009, 06:51 PM   #16
Again, the leak could be up much higher and running down the walls behind the shower pan. There could also be a small perforation in the liner. My guess is that all you have is a pan and no liner on the walls.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 07-20-2009, 08:16 PM   #17
Only gets worse.... the liner is only 4" up... how far should i go when i re-do
several 2x4's were water logged, and there is a boat load of mold... especially under the tile in seat it was gooey white mixed with mold almost like sheetrock mud.
Any good articles on building up my shower floor? Why 2 different mortars?
Ineedhelp2009 is offline   Reply With Quote
Old 07-20-2009, 08:42 PM   #18
Tileguy
Bud Cline's Avatar
Rewards Points: 558
The new liner should rise a minimum of three inches above the top of the dam.
The "gooey" could be mastic tile-adhesive which shouldn't be there at all.
We can furnish you with a good diagram of how it should bone. First get all the old out so things can begin to dry and you can do a further inspection.
I would also suggest you douse the entire structure that has been wet and moldy with a product called Microban.
Old 07-20-2009, 09:15 PM   #19
So the liner was done properly the first time?see pic? After tearing the whole seat down. There was TWO layers of tile on the top. Wonder if previous owner tried to bandaid a leak....The seat had the most mold on it.
Will continue to tear down and break away 1' up the wall update with pictures and get suggestions... Thanks
This is a first time for me ..
Old 07-20-2009, 09:54 PM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
As far as the height requirement, maybe. But, how were the corners done? Where were all the nails placed? How was the liner clamped to the floor drain?
Old 07-20-2009, 09:56 PM   #21
will take notes when removing floor... thanks again
Old 07-21-2009, 06:57 AM   #22
Do you understand that water transfers through grout and cement board? Do you know that if you don't have a membrane on the walls that moisture will get to them. The liner protects the floor and the membrane protects the walls. Does that make sense?
Old 07-21-2009, 04:40 PM   #23
Don't you hate how when you expect a repair to be a small project then it transforms into a larger project, it never fails.
cochise7969 is offline   Reply With Quote
Old 07-22-2009, 06:01 AM   #24
yea understanding now! I work in an office bare with me
Old 07-22-2009, 06:04 AM   #25
Would you suggest a tile redi pan or liner?
Old 07-22-2009, 06:07 AM   #26
Yep, bought this house last year. Got a really good deal since it was a foreclosure. 2nd major problem in 1 year!
Old 07-22-2009, 06:09 AM   #27
I think you really need to do some research. I would recommend looking up the kerdi ditra website and reading about the products they offer.
The membrane can have no penetrations and the reason for the cement board is that it doesn't mold and offers a solid tile substrate.
You might need a professional because there's a bit of a learning curve.
Old 07-22-2009, 06:48 AM   #28
Looking at site now thanks......Thanks for the info...
i would love to hire a professional....... just got jet skis 3 weeks ago and blew money fixing them up.......Don't have enough.....I was told this would be a 4K plus to hire someone.
I seen your site, nice work... what would you say a ball park figure is for this project if I hired someone?
Hopefully can take it slow and do it right.....or should i suck it up and put on credit card
Old 07-22-2009, 07:56 AM   #29
Chicago, IL
Michael Thomas's Avatar
Can't tell from your picture, but here in Chicago when tracking down the causes of shower leakage it's not unusual to discover that liners have been installed directly on the subflooring without the required mortar pre-slope.
Home Inspections, Infrared (Thermal Imaging) Leak Identification and Inspection Services, Roof, Attic, Building, Basement and Foundation Moisture Intrusion and Water Leak Inspections, Troubled Building Consultations - Serving Chicago and Suburbs http://paragoninspects.com/
Michael Thomas is offline   Reply With Quote
Old 07-22-2009, 08:30 AM   #30
You know this is the same-- wood then liner
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
