Shower Leaking Need To Re Tile - Flooring - Page 14 - DIY Chatroom Home Improvement Forum
Old 02-08-2010, 08:24 PM   #196
Originally Posted by Bud Cline View Post
I have myself convinced the best way to apply sealer on a ceramic tile floor is to use one of those cheap foam brushes. Apply only to the grout, watch it soak in for a minute or two then wipe off any that has gotten on the tile. With stone tile I use a spray bottle, let it soak a few minutes and wipe away any remaining pools. The bottle with the roller works pretty good to but with the foam brush the exact distribution is easier to control.
On walls, I do it the same way but walls are a huge PITA. Pay attention to the uncontrollable drips and runs and be sure to clean them up immediately.
sounds like a plan i like that idea.
will do, i bought the green bottle of tile lab
Ineedhelp2009 is offline   Reply With Quote
Old 02-10-2010, 09:06 PM   #197
Just sealed it showering tommorrow. I like the brush pretty easy with wife going behind me with sponge
Thanks again for all your help
Old 02-11-2010, 11:15 AM   #198
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Not a problem - GOOD LUCK!
XXX
Old 02-23-2010, 07:46 AM   #199
Let me ask.... I caulked the floor/wall juncture, but there are a few areas on lower wall by seat and a few grout lines on floor. They look wet even two days later without use. Seems like there is a leak or something and moisture is underneath... is this normal? I used the green bottle of tile lab sealer. I did it two times over everything. Do I need to let dry completely and do a third time?
Old 02-23-2010, 05:46 PM   #200
Tileguy
Bud Cline's Avatar
Rewards Points: 558
What happens if you probe the offending area and compare it to the other areas using the same method? Don't damage anything, just poke around a little and see if the the caulk is more firm in one spot than another. Something doesn't sound right.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
Ineedhelp2009 (04-20-2010)
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
