Shower Leaking Need To Re Tile - Flooring - Page 12 - DIY Chatroom Home Improvement Forum
Old 01-13-2010, 08:24 PM   #166
Originally Posted by Bud Cline View Post
HOLY CRAP don't be putin' no water in that thing!!!!
0 leaks will hopefully get all tiled this weekend
Ineedhelp2009 is offline   Reply With Quote
Old 01-14-2010, 09:04 PM   #167
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Just kidding!
XXX
Old 01-14-2010, 09:12 PM   #168
Just kidding!
i was nervous. I seen that post at 6 PM at work... haha did not get home until 7:30 i was sweating bullets the whole time
Old 01-14-2010, 09:17 PM   #169
Tileguy
Bud Cline's Avatar
Rewards Points: 558
SORRY!
Sometimes I have a weird sense of humor. I'm sure you'll be fine. So how long did you let the water sit in the receptor?
XXX
Old 01-14-2010, 09:23 PM   #170
SORRY!
all good, i will take a hit or two for the knowledge gained. 24 hours. hoping to be done in a few weeks. I AM TIRED OF walking upstairs in the cold.
I bought some color matching caulk/silicone. I plan to grout the walls but caulk shelf, seat, the edges going from seat to floor, curb and along the base of the floor. Sound good?
Old 01-14-2010, 09:35 PM   #171
Tileguy
Bud Cline's Avatar
Rewards Points: 558
You can do whatever you are comfortable with but if you have purchased 100% silicone I wouldn't use it if it were me. Siliconized caulk is OK, acrylic caulk is OK, but that stinking 100% silicone will ruin an otherwise good tile installation. Pure silicone (100%) is very difficult to work with and can ruin the tiles surface. Once it gets smeared on tile it is usually there to stay and is hard to eradicate. Proponents use alcohol to dress the silicone but that isn't easy and can make a helluva mess in the hands of someone not too experienced using caulk. A tiled shower such as this one is a showcase of one's ability and talents and using 100% silicone will put a guys pride and bragging-rights straight in the dumpers. If you are experienced with 100% silicone and comfortable with using it then go for it. If not, think about it for a while.
Sorry don't want to throw you a curve.
You can buy grout matching siliconized caulk also. Siliconized caulks can be dressed with a damp/wet sponge perfectly, 100% silicone cannot. Siliconized caulks can be cleaned up (when fresh) with water, 100% silicone cannot.
XXX
Old 01-14-2010, 09:42 PM   #172
ahhhhhh no wonder a few weeks ago when I tore out the grout and replaced with caulk. Where coutetops meet backsplash. I just checked it was 100% silicone and was a PITA. 2.5 tubes just to caulk 20' because I had to keep taking out and restarting.
Old 01-14-2010, 09:44 PM   #173
it was a special order from HD. THey knew my application. Hopefully it's right. 1 tube was almost $11
Old 01-14-2010, 11:04 PM   #174
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well then you know of what I speak.
Seriously as you have found out - a person can do more harm than good using 100% silicone when it comes to a tile installation.
Siliconized caulk that matches any grout color and comes sanded or unsanded costs about 7-8 bucks per tube at HD, Lowe's, Menard's.
XXX
Old 01-15-2010, 08:16 AM   #175
it's by TILE PERFECT non sanded. Siliconized. THATS GOOD!!!!!!!
Old 01-15-2010, 03:31 PM   #176
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK that's better!
XXX
Old 01-15-2010, 03:36 PM   #177
OK that's better!
quess I should have got sanded since my grout is sanded
Old 01-15-2010, 03:40 PM   #178
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OH WELL, not the end of the world. The color may look a little different because of the lack of texture from the sand but it should fly.
Keep in mind that the sand is a filler and reduces the potential for the caulk to shrink. Keep your gaps that are to be caulked small to reduce shrinkage.
XXX
Old 01-15-2010, 04:02 PM   #179
SOunds good to me
Old 01-17-2010, 09:43 PM   #180
well did not tile this weekend drank to much last night )))))
how would you approach this? Make that tiny cut so the wall tiles sit on top? Or fill gap with caulk? Of course when wall tile installed gap will be smaller? How would it look if cut was 1 block in? Maybe a few blocks in? almost like a 1/4 border....????
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 05:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 06:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 03:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 03:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 10:11 AM
