Shower Leaking Need To Re Tile - Flooring - Page 11 - DIY Chatroom Home Improvement Forum
Old 01-06-2010, 05:27 PM   #151
Originally Posted by R&D Tile View Post
Why buy more, just butt what you have there up to the wall, cut off the excess and use it on the other side up to the wall overlapping two inches, then install your kerdi band.
that one last piece hanging over will go on the other door frame you can seen in picture. I have to buy some either route since using 5" may not work.
Like bud said bulky. I still have to add the inner corners
Ineedhelp2009 is offline   Reply With Quote
Old 01-06-2010, 06:49 PM   #152
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Technically......
All "changes-in-plane" should be caulked, not grouted.
XXX
Old 01-06-2010, 07:19 PM   #153
Originally Posted by Bud Cline View Post
Technically......
is 2 3/4" from floor to curb to high? Looks like it. Should I add something to curb to make a little taller?
Old 01-06-2010, 08:35 PM   #154
Tileguy
Bud Cline's Avatar
Rewards Points: 558
OK now I'm getting lost again.
First you ask is 2-3/4" too high for a curb and you say "it looks like it". Am I reading it correctly?
THEN you ask if you should add to the height of the curb. I think your fine right where you are. In most cases this would work. There is no set standard, but generally a curb is around 3" on the inside of the shower and about six inches on the outside.
XXX
Old 01-06-2010, 08:43 PM   #155
I have lost you enough to write a book
Yes 2.75 inside, and around 6.5 outside
Old 01-06-2010, 08:57 PM   #156
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Go!
XXX
Old 01-06-2010, 09:02 PM   #157
Go!
i'll tell ya. I thought this was going to be $750 or less project. I just bought some 7" kerdi band. I am up to around $2000 so far. But I did get some new tools
Old 01-07-2010, 10:07 AM   #158
Go!
HD sells the caulk that matches my grout
Old 01-10-2010, 04:50 PM   #159
Is there anything I should change/fix? I am using corner pieces and I have 2 outters to go one the curb.
Old 01-10-2010, 05:13 PM   #160
Tileguy
Bud Cline's Avatar
Rewards Points: 558
All looks OK from my house!
I see the kids have been busy helping with the walls!
XXX
Old 01-10-2010, 06:01 PM   #161
Yea he shot out a few of the sharpies
The other 2 sides can wait until the floor dries, that bending over junk kills my back.
Hoping to do the other sides tomorrow and water test Wednesday!!! if that pans out should finish tiling sunday.
What is your choice of grout sealer?
Old 01-11-2010, 07:19 AM   #162
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Aqua-Mix is my usual choice in grout/tile sealers but Tile Lab from Home Depot works for me also.
XXX
Old 01-12-2010, 07:55 PM   #163
tile lab it is any particular one?
since i have made the 7 month post and its almost done here was my next step. About 2.5-3" of water..... will find out tomorrow if BUD was a good teacher ))))))))))
Old 01-13-2010, 04:32 PM   #164
Tileguy
Bud Cline's Avatar
Rewards Points: 558
HOLY CRAP don't be putin' no water in that thing!!!!
XXX
Old 01-13-2010, 04:42 PM   #165
I read that online from john bridge kerdI book
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
