Shower Leaking Need To Re Tile - Flooring - Page 10 - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 10:32 AM   #136
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Is the drain installed?
XXX
Old 12-20-2009, 02:56 PM   #137
no...just wood floor
Ineedhelp2009 is offline   Reply With Quote
Old 12-20-2009, 03:10 PM   #138
ask me how I know
I agree with Bud Cline, I think that has been there a long time. Make sure when you go back you use a product to KILL the mold. The common myth is that you can kill mold with chlorine bleach and that is just not true. Look for a mold and mildew remover with an ingredient to kill it. I also agree with the other poster that said do not use your tile and grout to mitigate moisture, but it is a good Idea to seal it all when done as insurance. The pics look great I could not have done better myself.
Groutonce
groutonce is offline   Reply With Quote
Old 12-20-2009, 03:29 PM   #139
Groutonce
Thanks for the reply. I ended up tearing out all wood with mold on it. I'll tell ya it was stinky for days
Old 01-01-2010, 07:19 PM   #140
please chime in while it's still wet...... YES I KNOW it's not the most level thing you have ever seen but will it work? SHould i change anything.
wish i would have put shelf closer to shower heads...
Old 01-02-2010, 01:39 PM   #141
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Now more KERDI? Is that correct? Then Kerdi-Band? Is that correct? Then what?
XXX
Old 01-02-2010, 09:17 PM   #142
soon to be done!!!! thats whats next
Old 01-04-2010, 08:01 PM   #143
will this work with band? Is the gap to big? SHould I go the other direction wth 2 pieces? If so I have to buy more
Old 01-04-2010, 08:56 PM   #144
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Depends on the size of the KERDI Band you use. Looks like the 7" band would work. Remember, you need a minimum overlap of 2", certainly no less.
XXX
Old 01-04-2010, 08:59 PM   #145
ahhh I have 5" that's where it leaked before I do not want to go cheap will buy some 7"
Old 01-04-2010, 09:04 PM   #146
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Good plan!!!
XXX
Old 01-06-2010, 01:53 PM   #147
Rewards Points: 26
Wow, this is a great thread by you and bud. Thanks for the thorough write up and the pictures. Can't wait to see it done and I'm sure you can't wait either. Must have a really patient wife!
One thing I don't think was mentioned and from reading seems like you may not know this since you were talking about clear silicone. They make silicone caulk to match your grout, sanded or unsanded. You might have to special order it or get it from a tile store and not HD but it looks really nice and matches the grout perfect.
ponch37300 is offline   Reply With Quote
Old 01-06-2010, 04:05 PM   #148
Why buy more, just butt what you have there up to the wall, cut off the excess and use it on the other side up to the wall overlapping two inches, then install your kerdi band.
R&D Tile is offline   Reply With Quote
Old 01-06-2010, 05:10 PM   #149
Tileguy
Bud Cline's Avatar
Rewards Points: 558
BE CAREFUL not to build-up too many layers of the KERDI products. The KERDI Band isn't as thick as the KERDI Mat. Too much bulk with seams and corner laps will give you crooked walls and humps and bumps.
More is not better in this case.
XXX
Old 01-06-2010, 05:26 PM   #150
Thanks and if it wasen't for bud I would have done a liner. (already bought but returned) I think this system will work and seems to be the best route for me, a first timer!
Would you say caulk my seat and floor seams where water will hit the most vs. grout... maybe grout the wall corners only?
Not sure if you guys have seen but I had a big post about jacking up my house as well. Cracking grout is a big possiblity in the future. It it still settling!
tile man used mastic glue on entrance to shower keyesww Tiling, ceramics, marble 13 06-08-2010 04:39 PM
water leak on tile shower floor redskins Plumbing 1 07-18-2009 05:58 AM
Shower tile specifics re: hair coloring Pammylu Tiling, ceramics, marble 4 06-05-2009 02:32 PM
Turning a tile shower into a one piece shower... chimera Remodeling 12 03-14-2009 02:30 PM
Honey, I'm going to re-caulk the shower... homebound Remodeling 1 02-10-2009 09:11 AM
