Shower Floor - Too Much Mortar To Make Up 1/2" Gap? - Flooring - DIY Chatroom Home Improvement Forum
Old 01-04-2012, 09:09 PM   #1
Shower Floor - Too much mortar to make up 1/2" gap?
Beginner here..I'm custom building a very small 36" x 36" shower. I've established the base flooring by pre-sloping using a 4 to 1 cement mix, then covered it with the rubber membrane, then added another layer of 4 to 1 cement. After installing the backerboard walls, I notice the outer edges of the sloped inward floor is not completely flush with the bottom of the backerboard walls. The largest gap is 1/2".
Can I make up this space by floating extra thinset morter when laying tile over the concrete shower floor? I fear using too much mortar, causing problems down the road. Advice appreciated!
usulax2 is offline   Reply With Quote
Old 01-05-2012, 04:50 AM   #2
DIY staff
Rewards Points: 7,174
The backer is usually installed before the pan is packed---Did you do the pan first?
If so---pack the gap with thinset as you tile---
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
Failed shower pan in old tiled shower tmpyankee Plumbing 3 07-14-2010 06:43 AM
Shower base mortar mix with acrylic fortifier zootjeff Plumbing 1 06-09-2010 05:42 AM
redoing basement shower - basic questions (relocating drain/options I have) mslide Plumbing 5 10-28-2008 10:42 AM
Mortar to use in floating a shower pan? kemerick Flooring 2 11-12-2007 01:35 AM
