Should Wood Planks Run Parallel Or Perpendicular To Doorway - Flooring - DIY Chatroom Home Improvement Forum
Old 07-09-2012, 11:35 AM   #1
Rewards Points: 113
Should wood planks run parallel or perpendicular to doorway
Want to install hardwood floor. Do i install planks perpendicular or parallel to doorway? Does it matter if planks are not perpendicular to floor joists? My floor is 16 o.c. - 2x10. thanks
EFTHIM is offline   Reply With Quote
Old 07-09-2012, 11:47 AM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by EFTHIM View Post
Do i install planks perpendicular or parallel...
generally... flooring is run in the long direction of the house/room.
but there are no laws to prevent other choices being used
Old 07-09-2012, 11:50 AM   #3
As long as it's T&G you can run it in any direction you can think up. Good luck !
CopperClad is offline   Reply With Quote
Old 07-09-2012, 06:40 PM   #4
Pro
JetSwet's Avatar
Rewards Points: 502
I don't know if that's entirely true, If the subfloor is of adequate strength then you could run it any way.
JetSwet is offline   Reply With Quote
The Following User Says Thank You to JetSwet For This Useful Post:
CopperClad (07-09-2012)
Old 07-09-2012, 06:47 PM   #5
Sorry.. They said 2x10's 16'' OC, I suppose I assumed it was T&G 3/4ply. To clarify.. When was the home built and what kind of plywood is sitting on top of your 2x10's?
The Following User Says Thank You to CopperClad For This Useful Post:
JetSwet (07-09-2012)
Old 07-15-2012, 12:53 PM   #6
Rewards Points: 113
The flooring is OSB and is T&G.
Old 07-15-2012, 01:23 PM   #7
Pro
JetSwet's Avatar
Rewards Points: 502
Then if your laying over osb T&G any way is fine, suggestion to run it longest way of the room would look better I think.
Wood over Concrete Stairs? Need Some Knowledge From You Guys jousley Building & Construction 26 06-27-2012 09:38 AM
Swift Lock wood vinyl planks samjamkm Flooring 0 03-28-2012 02:30 PM
install laminate wood planks on wavy concrete snucky Flooring 7 03-21-2012 12:29 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Wood close to Non-IC recessed lighting-solution? sjmonty Electrical 4 12-01-2006 09:14 AM
