Should Uniclic Flooring Be Nailed - Flooring - DIY Chatroom Home Improvement Forum
Old 11-05-2012, 07:03 PM   #1
Should uniclic flooring be nailed
I just purchased uniclic bamboo flooring from Costco. I understand that a sub layer should be placed down first and subsequently the flooring. Wanted to know whether the planks should also be nailed to the plywood floor.
stuchun is offline   Reply With Quote
Old 11-05-2012, 07:14 PM   #2
what does the manufacturer recommend?
Old 11-05-2012, 07:18 PM   #3
No never nail or staple a click floor. Its click for a reason and not solid tounge and groove
DonnHartwick is offline   Reply With Quote
Old 11-05-2012, 10:12 PM   #4
Thank you!
Old 11-07-2012, 04:18 AM   #5
Any flooring manufacturer that has a product worth installing will have a proper installation sheet contained in every carton of material, or online, typically both. Always, and I mean ALWAYS go to the manufacturers website and study the product installation file for your information, as well as any other relevant files. It doesn't matter what any of us say since we aren't going to be responsible for the warranty on your product. Always consult the source of the product (and I don't mean the store where you bought it) for the proper installation, maintenance, surface prep, adhesives, substrate requirements, etc.
RWCustom is offline   Reply With Quote
Old 11-07-2012, 02:15 PM   #6
Thank you very much!
How to Install Semi Solid Oak Flooring jastin123 Flooring 0 07-19-2012 12:51 AM
Installing Hardwood Flooring on Concrete Flooring, Condo slickwilly789 Flooring 1 10-08-2010 09:53 PM
Installing engineered flooring in the Philippines Flt_Simulation Flooring 15 07-21-2009 09:00 PM
Floating vs nailed flooring spidermite Flooring 1 08-22-2008 07:24 AM
