Should This Plywood Be Replaced? - Flooring - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 10:15 AM   #1
We're building a new house and it was not water tight for several weeks. The plywood in a few areas is delaminating and other sheets have deep ridges, pictured below. We need your opinions on whether the pieces with ridges should be replaced. Quite a number of pieces have this issue. The builder has already agreed to replace the delaminating sheets. We plan to have oak floors and porcelain tile with radiant heat in the bathrooms.
Also, once plywood starts to delaminate will it continue even if no longer subjected to rain?
TIA
2 threads on same subject merged
Teresa1127 is offline   Reply With Quote
Old 07-26-2010, 10:55 AM   #2
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 182
It needs to be replaced. I would worry about strutural integrity and it probably won't hold fasteners for your wood floor.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 06:47 AM
Subfloor repair Dave321 Flooring 3 09-16-2009 08:59 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 09:05 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
