Should A Modern Wooden Floor Lacquer Sealed Finished - Flooring - DIY Chatroom Home Improvement Forum
Old 01-17-2011, 10:13 PM   #1
Should a modern wooden floor lacquer sealed finished
My wife is saying that the new wooden floors as no sheen ,is it possible to give it sheen with out ruin the quality of the floor she said it needs to be waxed ?
Gates is offline   Reply With Quote
Old 01-18-2011, 07:13 AM   #2
Rewards Points: 1,642
What brand, style of floor is it? I would never wax a wood floor; slippery, it won't last, and you'll have a devil of a time if you go to refinish (if the floor can be refinished).
bob22 is offline   Reply With Quote
Old 01-18-2011, 10:00 AM   #3
This the floor that is in the house what kind of finish is appropriate for this type of flooring
Old 01-18-2011, 10:28 AM   #4
Experienced
Jackofall1's Avatar
The floor is either engineered, or 3/4" T&G both of which are prefinished. There are products at the big box stores, by the flooring manufactures, such as floor protector, not sure if this will increase the gloss or not.
I would not wax, nor would I try and reseal with urethane, unless you do a full sand job and restain and refinish, chances are the flooring was chosen with that satin finish, and the only way to change it is to refinish with a higher gloss.
Prefinished flooring is more durable, that being said, unless there is alot wrong with the floor, I wouldn't recommend refinishing either.
Old 01-18-2011, 12:24 PM   #5
Rewards Points: 200
sanding pre finish with aluminum oxide in it is no picnic.
Leave well enough alone .
Floor Doc is offline   Reply With Quote
smoke alarm was sealed off in finished basement Stl_home General DIY Discussions 4 06-22-2010 07:47 PM
Finished basement humidity at 80% for unknown reasons denemante HVAC 6 05-07-2010 03:33 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 03:11 PM
